Poor Mans Pumpkin Light/speaker
Published
Introduction: Poor Mans Pumpkin Light/speaker
About: I like to make things But im limited on tools so most of my instructable are crude
I will show you how to make a poor mans Pumpkin light/speaker
Step 1: You Will Need
PLAN A
Plan A is where you will take a speaker and then connect a audio cord or a audio jack to it.
PLAN B
Plan B is where you will take a pre made speaker (this is what i mean https://goo.gl/HX4U4q, YOU DON'T have to get that certain one) (if you have a Iphone 7 then you will need a wireless speaker)
You will need:
Light ( better yet LED strip )
cutting tool
marker
Thin wire or fishing line
something that plays music
plastic pumpkin
Hot glue ( or any other glue )
fabric
Plan A specific things
- speaker
- audio jack or audio cord
- Lighter
- heat shrink tubing
Plan B specific things
pre made speaker
M.P. : Music Player
Step 2: Pumpkin, Marker
Take the maker and draw a outline of the M.P.
Step 3: Cutting Tool, Pumpkin
READ/ LOOK CAREFULY
Cut where i show you in the picture
Step 4: Speaker, Wire or Fishing Line
tie it equally on each side
Step 5: Cutting Tool.. Better Yet a Drill With a Tiny Drill Bit
drill 2 holes opposite from each other
then tie the wire so the speaker hangs
Step 6: Done
I just put sand at the bottom to keep it from falling. Then I hot glued cardborad down so it would not com out. ( And hot glue all around the edges )
And I put a light where the iPod is supposed to be because I think it will work better.
    • Creative Misuse Contest
    • Stick It! Contest
      Stick It! Contest
    • Backpack Challenge
      Backpack Challenge
    Thank you for comimg
    (PS: this is in a contest, you should go check it out)
