loading
Step 3: Building the base/heat strip and wiring.
-Take the sheet metal (must be longer than the heating element, or series of heating elements if you wish to make the heat strip longer) and cut out tabs to be bent perpendicular to the rest of the sheet metal.
- Drill holes on the tabs to thread the heating element through.
- Wire one lead of the power cable to one lead of the dimmer switch, and the other lead of the dimmer switch to one lead of the heating element.
- Wire the other lead of the power cable to the other lead of the heating element.
- (Since the heating elements work on A/C current, you can disregard rectifying the current, and you can disregard which lead of the power cable goes to which lead of the dimmer or heating element.)
Optional:
- Mount metal pipes (with nuts and bolts or cut tabs on the sheet metal and bend them in towards the pipe) parallel to the heating element, with an about 1 inch gap from the element.
- Apply liquid electrical tape to seal any exposed wires (don't want to be electrocuted. I used tape)
Nice! I am cannibalizing the controls from the toaster also- the timer and temp controls are already there, so I am gutting it instead of smashing it [that comes later].
Pretty awesome make-shift heater. Certainly a different purpose than these heaters, but still nice not to have to spend so much: http://www.regaltool.com/Drum-Heaters-Barrel-Warmers
Just as a thought would this work for bending an arch into a strip of plexi-glass? If anyone has any idea's on how to get a peice of plasic into an arch please tell.
I would imagine it might need a bit of trial and error if you are going to use an standard oven. a temperature of between 140-160 degrees centigrade works best&nbsp; for rigid foam pvc sheets.<br /> An easier way in DIY situations might be to build a jig or former the required shape, and use a hot air paint stripping gun, applying localised heat and working your plexigalss around the Jig. <br /> You must clamp it in position and allow it to cool completely before removing it, If it is anything like rigid foam it will hold its shape.<br /> Thai plastwood have a series of guides to working with plastic. Check out: www.thai-plastic-wood.com/plastic-uses.html<br />
A while back, I wanted to bend a strip into a parabola, and was trying to think of ways to do it. I saw a video a while back where someone placed a sheet ontop of a parabolic dish and stuck it in the oven. For a strip, perhaps if you taped the ends so that you're adding tension (curves it parabolic like) and place it flat in the oven, that might work.
BriskHeat offers an inexpensive plastic bending strip heater at <br/><br/><a rel="nofollow" href="http://www.briskheat.com/p-152-rh-plastic-bending-strip-heater.aspx.">http://www.briskheat.com/p-152-rh-plastic-bending-strip-heater.aspx.</a><br/><br/>Over 60 years of flexible surface heating experience. <br/>
Do you think this could be done using "long" halogen floodlight bulbs as the element? I'm just thinking they give out alot of heat, with the electric safely contained inside a nice glass case. and if done with only a strip exposed as mentioned below you would have a clear indication of where the heat was going as it would be going the same way as the light. I think I may have just thought of my first instructable.
Why am I a colaborator to this instructables?
<pre>my tech teacher in highschool had one built something like this, but he had bent sheet metal around it makeing a flat serface so that the heat would rise through a gap in the metal |-- --|| O |&lt;--- from the side, the O is |_______| is the heater so the heattravels up through the gap and melts whatever is on top just in that little spot so we could bend very acuratelyand all this would take to build is putting 4 bends into some sheet metal and suspending the element somehow</pre>
good use of the "pipe"symbol cmon bend that
<a rel="nofollow" href="http://www.modernplastics.com/plastrip-heater-p-1229.html">http://www.modernplastics.com/plastrip-heater-p-1229.html</a><br/>
<a rel="nofollow" href="http://www.usplastic.com/catalog/product.asp?catalog_name=usplastic&category_name=59&product_id=2301&cookie%5Ftest=1">http://www.usplastic.com/catalog/product.asp?catalog_name=usplastic&amp;category_name=59&amp;product_id=2301&amp;cookie%5Ftest=1</a>Or here: <a rel="nofollow" href="http://www.usplastic.com/catalog/product.asp?catalog_name=usplastic&amp;category_name=59&amp;product_id=2301&amp;cookie%5Ftest=1">http://www.usplastic.com/catalog/product.asp?catalog_name=usplastic&amp;category_name=59&amp;product_id=2301&amp;cookie%5Ftest=1</a><br/>if you don't want to spend a minimum of $100 US.<br/>
just an idea but, couldn't you use the dimmer already included in the toaster? ( the thing that makes toast dark or light colored.)
Yea, I could've but the way toasters are made, the dimmer device and timer mechanism are cobbled together and it's very weird to work with.
One method for bending plastic pipe (plumbing-sized) I have never tried, but have had described by a couple of commercial plumbers. Apparently you can soften PVC (up to about 2") by attaching a tube to the exhaust of your truck and letting the exhause heat do the work gradually. My understanding is that they usually have some homemade adapter fitting stuck onto the exhaust, and sometimes they partially block up the "cold" end of the length of pipe, to keep more of the heat inside to soften the material. I don't think this is done every day onsite, but just occasionally when a run of pipes just doesn't quite match up and needs to get a bit skewed to meet another run of pipe.
This looks great for vacu forming! Perhaps a little adjustment to the heating element position -- but methinks it could work :D
For vacuum forming, you want an area heater, not a strip heater. For local bends, you want a strip heater.<br/><br/>Check out my article on a small (12 x 20 inch) vacuum forming oven for under $30 using a two-burner hot plate and disposable aluminum pans:<br/><br/><a rel="nofollow" href="http://www.rcgroups.com/forums/showthread.php?t=621858">http://www.rcgroups.com/forums/showthread.php?t=621858</a><br/><br/>
You think this will work for plexiglass too? I recently had an experience trying to working with plexiglass and a bender would come in handy!
Yea, it works. Be a bit careful tho. The plastic bubbles a little when heated and it might show on plexi.
The bubbling is due either to heating it too fast, or moisture in the plastic. Acrylics absorb moisture from air (humidity) and when you heat them up, the moisture can turn to steam and make bubbles. If you bake the plastic at 200 for about a half hour per millimeter before thermoforming it, that will drive off the moisture and eliminate the bubbles.
Cool! Would this also work for bending plexiglass?<br/><strong>Safety concern, tho:</strong> Doesn't this mean 110V (or 220, in Europe) will appear across the heating elements, making you, the user, potentionally... toast..? :p<br/>
Any thermal plastic. And yea it's pretty dangerous. But then again, so is operating a toaster oven (it's just a stripped down toaster oven minus the timer.)
<strong>Solution to safety concern</strong> I agree 100% - that's insanely dangerous. You can, however, get an isolation transformer. It doesn't affect the power in any way, it just prevents power from flowing back to ground through you. They're cheap ($30 range) and can be found with a little effort. Realizing that some people may only want to spend $10 to save their life... *ahem* You could go to radio shack and get two identical transformers (make sure they are rated for your toaster's power) and put them back to back. I.E. go from say 120V to 24V and then from 24V back to 120. <br/><br/>Just remember - if you touch the heating element by itself, it'll burn. But if you touch it w/ live power across it, it could kill you - not smart.<br/><br/>
This is a godsend, and so cheap! I think that all thrift stores in existence have at least one toaster oven. What a great and simple idea, and still open to modification. I can now do all the things with plastic that I've been wanting to do for a while now.
i'm so glad you posted this - i've wanted one forever, and knew i'd be better off to build one, but i hadn't gotten around to figuring it out yet.
With a few more pipes, you could make a quick'n'dirty slip roll for making curved shapes and tubes.
Not to offlink, but here is a guide that my friend made for one of these.<br/><a rel="nofollow" href="http://www.austinpcmods.com/how-to-story--1.html">http://www.austinpcmods.com/how-to-story--1.html</a><br/><br/>He sunk the heating element into the wood, which works very well as you can just place the plastic flat on the surface.<br/>
cool
How are you connecting the heating elements, just twisting the leads together or what?
yea, you can't solder them together because the heating elements achieve the temperature where solder melts. You can, however, weld them together
Are you using the sheet metal as a reflector, heat-shield (for the wood) or both? L
heat shield, and somewhat like a reflector/director. But initially just a shield
About This Instructable
133,022views
150favorites
License:
Bio: I'm an electrical engineer specializing in software. My hobbies consist of software, hardware, and design. I dabble with industrial design.
More by xeijix:Game of Thrones: Joffrey Baratheon's Crown The Legend of Zelda: Skyward Sword Goddess Chest 3D modelling cases, chassis, etc
Add instructable to:
