Step 3Getting started
find a picture or drawing that you like and print it to
fit the side of your cup, or trace the design with the
tracing paper. tape the design to the cup using scotch
tape to hold it firmly in place. following the lines of the picture or design, poke
gently but with pressure along the lines leaving small
pricks through the paper into the plastic. when all the
lines are covered (check by holding the cup opening to a
stong light source, you will see small holes through
your image.) carfully remove your paper design from the
cup and using the black marker, color over the small
dimples left by your poking needle. let it dry for a
minute. then dampen your rag wth a little rubbing
alcohol, and wipe away the black ink. you will be left
with a picture that resembles a childs dot to dot
picture. hopefully you did not press to hard, you only
want to barely be able to see them.
Add Comment
