loading
Step 5: Make the Spine of the Bracket
Pictures are better than words here, but here's an approximation. This is the part that will vary considerably with the design of your car.
Bend the two wire legs so that they curve down, meet, and turn around. Then bend the remaining legs outwards, like arms outstretched to hug the antenna post (which they will). Test fit it, and bend it around as needed until you like the look and the cap is more or less centered over the hole. Wire's pretty forgiving.
If you're using steel wire, feel free to solder up the spine. This will make the bracket stronger, but also decrease your margin for error, so make sure it's right where you want it before you plug in the iron.
<p>sugru around the edges on the cap and mount might improve weatherproofing and remove the scratching concerns.</p>
Brilliant! It's quirky, cool. What a neat conversation piece. I think it's awesome.
Yes. Awesome.
A nice idea, but I would think that over time the edge of the bottle cap would scratch the antenna. <br> <br>I think a more plausible solution would be to simply drill one or two holes in the bottom of the antenna motor housing, to allow drainage. You could also attach a piece of vacuum line to direct the drainage if you wish. That's all they really do on the ones that are made to do this already.
They have that. They don't work in this instance. Water goes in, then it sticks in the plastic gears, freezes over night, and then in the morning you turn your car on with the radio on and ST-T-T-T-T-T-RIP goes the gears.
Ah! Well that just sucks!!! lol
nice man! <a href="http://www.google.com">Kudos!</a>
TOO COOL!!<br><br>I applaud your creativity here! Excellent mod!
Great project XD It's one of those ones that brings a goofy smile on my face when I see it working.
Very clever!<br> My only recommendation would be to <strong>clean your fingernails</strong> before your next post on Instructables - sorry, but it's gross!
Kinda have to agree. Great idea but clean your fingernails, wash behind your ears and sit up straight! ;-)
Comb your hair and don't talk with your mouth full!
And always wear clean underwear in case you get in an accident. :-p
are you the guy with the lime?
If you've got a problem with a little dirt under the nails, perhaps you're on the wrong forum. I mean *really*!<br><br>I was about to comment that the poster's nails were of the perfectly appropriate length in order to serve as the God-given, free and incredibly useful tools we were all born with...dirty or not. Too many folks clip, grind, chew or otherwise mutilate their nails until they are nearly useless appendages. <br><br>If they only knew how useful fingernails are; but they never will.
LOL sorry about that. The stuff on my thumbnail (I assume that's what you're talking about) is spray paint, wearing off slowly (because I don't wash with paint thinner). If it looks nasty now, you should've seen it when it was fresh. XD
I can photoshop it out if you want - you are an amazing maker.
If you are that picky, obviously you don't do much work. My fingernails get cleaned every day besides hand washing and showering, but then dirty again a few minutes later.
Wats up, Ac-dc? dont you remember me? its Tesla! I invented half of you!
Glue a bottle cap to the top of the aerial, so when it lowers, it covers the join. No moving parts.
That could become an aerodynamics problem for the antenna. <br> <br>Adding a bottlecap drogue chute on the end could modify the antenna into a new instructable - how to replace a bent/broken power antenna. <br> <br>Your mileage may vary, depending upon road conditions and driving habits. ;) <br> <br> <br> <br>
Funny you should mention that, I thought the same thing the morning after I finished this. Either would work, and yes, the bottle cap glued to the antenna might even work better. But this is more fun to watch. XD
Attach it with sugru - will glue the cap to the antenna and act as a seal when its closed. Awesome.
Good idea - but we don't have that product here.
I only buy it on the internet from their website.
Mine's a non-retracting 3&quot; steel tube schnorkel which does double duty as an FM radio aerial at the same time. Also (mostly) protects the cellphone aerial from branches etc. Also, I don't get ice problems because I park in a carport. <br><br>Nice fix - good work.
Nice job. I got a good laugh out of it (in a good way.) My Camry suffers from the bent antennae phenomena. I've given up on my power antennae.<br> <br> One suggestion though. You might want to find a way to prevent the cap edge from being sharp. Or perhaps it is better to say you want to prevent any scratching and keeping the friction to a minimum.<br> <br> Great idea. Sometimes the simplest ideas are the best, and the most fun.<br>
Good idea, but I think there may be risk of electrically grounding the antenna with the bottle cap (shorting the radio signal). Perhaps we can use a pill bottle cap or a similar one made of plastic.
The assembly's glued to plastic, so I don't think it's doing much grounding (I haven't noticed any change in signal strength). Good thought though, I didn't even consider signal issues when I designed this.
I was not thinking of a DC short but of a RF short caused by the stray capacitance between wire and metal (surely not noticeable in the low frequency AM band).<br>Still, you have not noticed any change in signal strength, so I was wrong in this regard. The only other consideration with the metallic cap is the possibility of rust.
i have used bits of spring steel to make fine cut tools for wood and clay (my wife makes silver clay jewelry) those on dowel rods are perfect <br>
You are a king ! Very good thought process here. I myself 'ain't that' clever. To all those people who commented on your finger nails- You need to add a section to the build to outline using spray paint. Make sure you stress that the builder should not wear latex gloves or what not, because the paint will melt the gloves. THEN everybody would have paint on the nail's, so to speak. Great job- now where did I put the spray paint...
i dont have an antenna like that. but this makes me want one like it. very cool. i like it.
You have made a beautiful thing.
wow thats such a clever simple design, congrats
I agree with the kudos. While I would probably obsess and try to find something a little more 'elegant' to put on my car, on reflection this is perfect. The build quality and instructions are superb, although I'd like to see a little more 'macro' in the photos to detail the bending/binding of the spring onto the mount.<br><br>That said, I also agree with the poster who suggested a simple 'top-hat' design would be simpler. Perhaps that could be combined with some sort of socket collar around the base in order to make a better seal...or an O-ring under the top-hat section itself for simplicity.
Very nice 'structable!! I like simple, elegant design, and this has it.<br>Now, as a lil present to those so unfortunate as not to have such a power antenna, why not glue (or Sugru) a bottlecap the the tip of your existing antenna!.. Watch others as they stand in disbelief that you have a power antenna in a place where its impossible to have one! and, of course, with no moving parts ..<br><br>(I think its more elegant than those dumbo lil plastic balls they fix to antenna tips, anyway)
I know it's a crazy thought, but if you replaced the power antenna with a fixed antenna you'd not only fix it, you'd never have to worry about the motor or gearing breaking someday... just a thought...
Yes, but where's the fun in that?
reading through all the comments, yes, there may be more elegant looking solutions ... but I personally like this one ... it just has a little steam-punk-ish flare to it that adds character. Good job!!
Nice, and well instructed! Short little video of the antenna pooping out and moving the cap on and off would be the finishing touch!
Huh huh, you said &quot;pooping&quot;, huh huh.<br><br>Sorry, couldn't resist. Anyway, awesome instructable, if I had a car, I would so build that.
That is kinda funny, guess it kinda works still as a verb for what it is doing, something coming out of a hole... turtle style. Ok, I'll stop.
Thanks! I've attached a video (I think I did it right?), but it's a bit dark; I'll get a better one up on Youtube and link to it. :-)
Video does work, but once you upload it to youtube, and embed the link it will be better. Often people appreciate the ability to simply click on the given screen rather then to have to open it with another application. Otherwise pretty slick!
Good point. New vid is up, and embedded. :-)
We need more people like you in this world
Very cool, <br><br>reminds me a of a Power Antenna cover for the Old Cadillac Deville. But yours has more style!<br><br>Well done!
Do you have a &quot;.mov&quot; version of your video?
Couldn't you keep the moisture out better if you added a little ring of inner tube round the inside of the cap that protrudes from under it just enough to touch the body of the car / thing the antenna comes out of? although even without that this is still an amazingly inventive idea ^_^
About This Instructable
30,405views
57favorites
License:
Bio: I do most of my tinkering and modding on a "what can I find in the trash" budget, and enjoy fixing things, especially when someone ... More »
More by Darwinfish:Keeping Terriers out of Cat Food (and litter boxes too!) Pop-Bottle-Cap Antenna Protector
Add instructable to:
