Remove these ads by
Signing UpStep 1Gather Ingredients
~ 1 Tsp Baking Soda
~ 1/4 Cup Citric Acid Crystals (Can be tricky to find. If your local gourmet/country store doesn't have them, try here .)
~ 1/3 Cup of Corn Syrup
~ Small amount of Water (Just enough to get sugar wet)
~ 1/4-1 Tsp Flavoring (any extract will work. Use what you like! When using stronger flavors such as cinnamon, mint, and cherry, you can use a small amount (about 1/4 teaspoon). Subtler flavors such as lemon, strawberry, orange, and peach require more (1/2 to 1 teaspoon.)
~ A Few Drops of Food Coloring of your choice
~ Candy Thermometer (Make sure it is properly calibrated. Put some water on to boil and put your thermo. in. Bring the water up to boil and see what the temp. is when it starts boiling. You may have to adjust the paper inside to set boiling point to 212°F. Then you know it's ready to go.)
~ Medium sized Saucepan
~ Whisk
~ Pastry brush
~ Powdered Sugar
~ Large Cookie Sheet
~ Zip-top plastic bag
~ Blunt Instrument ( i.e. hammer, brick, lead pipe, etc.)
Also as a caution, speaking chemically, these will be salty. However, I can't speak from trying this recipe specifically.
Feel free to change the recipe if you want. Out of all the experiments we tried with them, this version came out the best. You can try adding the 1/4 citric acid when you add the baking soda. That will start the reaction early though, leaving them less fizzy. Try it out. We liked these the best, but try them another way if you want. That's what makes cooking fun! Experiment a little!
Thanks for the response though!
"homemade chunks of awesome"
Thanks for the chuckle!
If you can weld, and know how to understand stresses caused by pressure, and not a contact point, then you should have no problem creating the CO2 version.
Wouldn't it be nice to get the real deal? (Although unless you eat these things for supper, I doubt you'll ever eat enough to gain the savings needed over purchasing all the equipment.)
I'm glad that you posted this so now that I don't have to build my suicide pop rock machine.
Very cool!
I've considered the possibility of building a pressure cooker, but i think I'd like to keep my limbs. Perhaps if you'd like to do a joint venture sometime... :) Anyway, these are a neat alternative.
Thanks again for your support!
You're going to be looking to use 1\8 - 1\4 inch carbon steel at least, so all of you figuring you're going to go make something out of a pressure cooker, you're setting yourself up for a whole mess of 3rd degree burns!
It does use CO2 (from a chemical reaction) to make it light and airy, but Pop Rocks require CO2 to be injected at high pressures. It is the pressurized gas escaping that makes the pops.
This doesn't sound impossible to me, and compared to other ibles, it now seem probable that someone will take this and make it real.
nice instructable
I must clarify to all I just confused, you put a serving in a small sandwich bag, then close them 99% . Then you put them flat in a large vacuum bag (clear see through plastic seal that and evacuate the big bag, which evacuates the little ones (cheapo bags). Run a finger over the seals of the small bags so they are sealed up (inside the big bag under vacuum)then release the vacuum to the big bag. take all the little bags put in vacuum jar and evac that. (you can make a jar for a penny or less)
cheapo bags won't keep a vacuum long, but stored in a vacced jar they will keep very nice and allow you to remove them and take them on a trip to park etc and still keep good explosive sillyness for all to enjoy.
http://www.reddit.com/r/reddit.com/comments/8ue5i/outpouring_of_support_from_reddit_keeps/c0ah12r
Do you think this would work?
A quick note about calibrating a candy thermometer for those who are not at sea-level: a good rule of thumb is the boiling point of water drops by about 1 degree F for every 500 feet in elevation gain. So, for someone in say, Denver (~5000ft), the boiling point is 202 F instead of 212.
