3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pop Rocks!
Pop Rocks!
Pop Rocks!  Love 'em or hate 'em, you have to admit these tiny candy crystals pack a neat little punch.  This candy takes me straight back to my childhood!  They can be hard to find sometimes, so here's how you can make a similar substitute with some surprisingly common ingredients.
Step 1Gather Ingredients
Gather Ingredients
~ 2 Cups Sugar
~ 1 Tsp Baking Soda
~ 1/4 Cup Citric Acid Crystals (Can be tricky to find.  If your local gourmet/country store doesn't have them, try here .)
~ 1/3 Cup  of Corn Syrup
~ Small amount of Water (Just enough to get sugar wet)
~ 1/4-1 Tsp Flavoring     (any extract will work. Use what you like! When using stronger flavors such as cinnamon, mint, and cherry, you can use a small amount (about 1/4 teaspoon). Subtler flavors such as lemon, strawberry, orange, and peach require more (1/2 to 1 teaspoon.)
~ A Few Drops of Food Coloring of your choice
~ Candy Thermometer (Make sure it is properly calibrated.  Put some water on to boil and put your thermo. in.  Bring the water up to boil and see what the temp. is when it starts boiling.  You may have to adjust the paper inside to set boiling point to 212°F.  Then you know it's ready to go.)
~ Medium sized Saucepan
~ Whisk
~ Pastry brush
~ Powdered Sugar
~ Large Cookie Sheet
~ Zip-top plastic bag
~ Blunt Instrument ( i.e. hammer, brick, lead pipe, etc.)
39 comments
Feb 21, 2012. 2:24 PMmygibzone says:
Pop rocks were always a childhood favorite. I'm excited to try this!
Jun 20, 2011. 7:42 AMslaveboy2000 says:
there a taste sensation .I made peppermint , maple and orange . peppermint is my favorite and it fizzed/popped the most .I like the recipe . :) =)
Nov 6, 2011. 1:19 PMWoodstock Candy Lady says:
I love this recipe for Pop Rocks!
Sep 18, 2011. 1:33 PMSD456 says:
Thank you very much for this instructable! I was looking for these for ages :)
Sep 15, 2011. 4:23 AMbakesalot says:
that is so cool! glad I found this (:
Jul 8, 2011. 4:39 AMzilcho says:
It wouldn't be too hard to make a device capable of holding a lot of pressure to put the molten candy in. Then just add a lot of dry ice and seal it off.
Jun 18, 2011. 1:31 PMLangarulz says:
its hardly ever not dry in AZ
Mar 21, 2011. 3:29 PMduckythescientist says:
The fizzing here is the same process as the fizzy Skittles. I hate those Skittles; they taste salty. This reaction will also make sodium citrate, so I am worried that if I make these, I will equally dislike them. Have you or other people found these to be salty?
Also as a caution, speaking chemically, these will be salty. However, I can't speak from trying this recipe specifically.
Mar 22, 2011. 4:43 PMduckythescientist says:
I'll probably just wait until someone figures out a way to (safely, at home) use nitrogen instead of an acid base reaction.
Thanks for the response though!
Mar 17, 2011. 11:15 AMjenjenbug says:
Best phrase of the day, E.V.E.R.
"homemade chunks of awesome"
Thanks for the chuckle!
Mar 18, 2011. 12:09 PMMaXoR says:
How about "I feel better than a tub full of good things" - Freakazoid
Mar 19, 2011. 10:24 AMjenjenbug says:
Not bad!
Mar 17, 2011. 8:38 PMeyewalk says:
Any recipe with a hammer listed as essential equipment has got my vote!
Mar 18, 2011. 12:22 PMMaXoR says:
Too true.... destruction is fun (Remembers back to the toys in sandbox days.... aww so much destruction)
Mar 18, 2011. 12:20 PMMaXoR says:
I like this idea, and although these will only fizzle, or froth in your mouth.... it's the safest solution for at home, well safest for those without welding experience, and a background in engineering.
If you can weld, and know how to understand stresses caused by pressure, and not a contact point, then you should have no problem creating the CO2 version.
Wouldn't it be nice to get the real deal? (Although unless you eat these things for supper, I doubt you'll ever eat enough to gain the savings needed over purchasing all the equipment.)
Mar 8, 2011. 4:00 PMrandofo says:
For years I have been considering making them with all kinds of serious industrial equipment. It's not an easy feat heating something to 300 degrees and then pressuring it to 600 psi. This mildly frightens me to try.
I'm glad that you posted this so now that I don't have to build my suicide pop rock machine.
Very cool!
Mar 18, 2011. 12:17 PMMaXoR says:
DO NOT ATTEMPT TO MODIFY A PRESSURE COOKER, THEY ARE DESIGNED FOR UNDER 20PSI!!!! The metal walls alone will likely bulge already at 30, and might simply explode apart at 50-80.
You're going to be looking to use 1\8 - 1\4 inch carbon steel at least, so all of you figuring you're going to go make something out of a pressure cooker, you're setting yourself up for a whole mess of 3rd degree burns!
Mar 8, 2011. 8:16 PMhlfwy.thr says:
Cool! Didn't know you could make these at home. I'll have to try it out/.
Mar 18, 2011. 12:15 PMMaXoR says:
Keep in mind he said they were "LIKE" pop rocks, although these will only fizzle, or froth in your mouth. The same experience can be had with vinager and baking soda, since it's the same reaction your creating.
Mar 17, 2011. 2:04 PMvanmankline says:
Nice detailed instructable, however this is closer to a seafoam or sponge toffee. True Pop Rocks can not be made a home, although this is still a great candy.
It does use CO2 (from a chemical reaction) to make it light and airy, but Pop Rocks require CO2 to be injected at high pressures. It is the pressurized gas escaping that makes the pops.
Mar 18, 2011. 12:08 PMMaXoR says:
I almost wonder if there isn't an IBLE here for that CO2 version to create REAL pop rocks. Sure 600 PSI is huge, but it's about what is available in a CO2 cartridge isn't it? So why couldn't you just heat up the sugars, then have a sealed system that allows a CO2 cartridge to be evacuated into the mixture?! Im also assuming that you simply have to cool the sugar after the CO2 has been added, although it must be cooled at 600 PSI until hard.
This doesn't sound impossible to me, and compared to other ibles, it now seem probable that someone will take this and make it real.
Mar 17, 2011. 10:39 AMspark master says:
for storage use a bottle with a vacuum seal and pump out the air. You can make your own resealable vacuum bottles and use a commercial vacuum pump or build a pump. If you use the reynolds system (I have one) they have various sized bags, so you could put P-R's in a few put them in the big bag (99% sealed, then close the big bag, cauum it press the smaller bags closed (inside the sealed evacuated big bag) and then pu them in a big jar which you vacuum as well. Cheap bags don't work well over time , but in a jar they will do fine allowing no degaidation as you open then close the big bottle to give treats to kiddies, ok adults too.
nice instructable
Mar 18, 2011. 8:06 AMspark master says:
that toy cost so much , ya gotta use it once in a while!
I must clarify to all I just confused, you put a serving in a small sandwich bag, then close them 99% . Then you put them flat in a large vacuum bag (clear see through plastic seal that and evacuate the big bag, which evacuates the little ones (cheapo bags). Run a finger over the seals of the small bags so they are sealed up (inside the big bag under vacuum)then release the vacuum to the big bag. take all the little bags put in vacuum jar and evac that. (you can make a jar for a penny or less)
cheapo bags won't keep a vacuum long, but stored in a vacced jar they will keep very nice and allow you to remove them and take them on a trip to park etc and still keep good explosive sillyness for all to enjoy.
Mar 17, 2011. 6:45 PMRemag1234 says:
$15 from Amazon, that would buy a lot of pop rocks.
Mar 14, 2011. 6:35 PMhappysmurfday says:
I'd really like to make some sizzling bacon pop rocks. I found this recipe for bacon extract:
http://www.reddit.com/r/reddit.com/comments/8ue5i/outpouring_of_support_from_reddit_keeps/c0ah12r
Do you think this would work?
Mar 15, 2011. 7:17 AMmikelike says:
These look so good though I am pretty sure my teeth will disagree with me.:))
Mar 14, 2011. 10:32 AMtvincent says:
Most homebrew supply shops also carry citric acid, it gets used in home wine-making occasionally.
Mar 14, 2011. 7:42 PMdwhole says:
You can also find it as sour salt in most grocery stores - in the kosher section usually.
Mar 13, 2011. 12:49 PMnetlog111 says:
Citric acid is also used in homebrewing, so you can find it where those supplies are sold.
Mar 12, 2011. 5:11 PMthread_soul says:
Awesome! I would never have imagined this was feasible to do at home. It's definitely going on the list of weekend projects.
A quick note about calibrating a candy thermometer for those who are not at sea-level: a good rule of thumb is the boiling point of water drops by about 1 degree F for every 500 feet in elevation gain. So, for someone in say, Denver (~5000ft), the boiling point is 202 F instead of 212.
Mar 9, 2011. 10:31 AMJimKelleher says:
My local supermarket stocks the citric acid crystals with the canning supplies. I use it to make an acid dip to pretreat apple slices before dehydrating them to keep them from turning brown.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
11
Author:chickflix
