Turn aluminum can tabs into cool jewelry!
Remove these ads by
Signing UpStep 1Gather your supplies
You also need elastic cord and scissors. That's it! No other supplies necessary.
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
I didn't have any elastic cord lying around but I did have four sets of broken earphones, I used one side of a split earphone cord and had plenty left over. It's a bit of a squeeze without it being elastic but I've left just enough space for it to not be uncomfortable and not too much for it to slip off.
It still needs some painting which I probably should have done before I made it but oh well!
tops! It looks cooler and it has color!
Grr...Fear Me (thats my phone singature to)
I can't understand you. Are you sure you can't move your fingers just a _little_ bit more, so that you actually type words instead of numbers? Or do you need typing lessons? I'm sure you can find typing games...
It's called a "reversible". You just invert the original bracelet. It won't have the X's from the elastic.
Good job!
Since you probably don't have that, just use a strong emery board.
If you don't know what that is... It's a nail file.
If you do have sandpaper, cut a little piece, attach it to a craft stick using glue and file down the sharp edges. Good job.
get the bead string from walmart :D
I made 2, a yellow and silver one for my neighbor who kindly donated lots of tabs. And a pink and silver one for me. BTW, thanks to the people with the monster tab hole-punching comments, helps a lot, 'cause I just realized about the one hole. :P And the images are from a video I found which wasn't as clear as these instructions. :) Now all I need to know is if it'll break my hole puncher...
... Hmmm...
~SDNT
http://wwwanna889.blogspot.com
http://wwwanna889.blogspot.com/
Grr...Fear Me
also could you somehow find out exactly how many tabs you need for a wrist?
