3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pop-Up Pyramid
Pop-Up Pyramid
How to make a pyramid pop out of a plain piece of paper.
Step 1Draw a square with a couple of gaps
99 comments
1-40 of 99next »
Oct 27, 2011. 9:32 AMplayful-geometer says:
This looks really fun, I think it could make some fun deco attaching them to ceilings. If I do end up giving it a try with my CraftRobo Pro, I'll post my cutlines...
Mar 23, 2011. 2:17 PMmalialtin says:
These are a few of my trials... If you choose irregular gap widths and lengths between lines you will have a 3 dimensionaly self bending form while it is hung from apex.
Jan 12, 2011. 9:55 AMfoks says:
thinking about projection from the top on this. im making pyramid to test
Oct 24, 2010. 8:43 AMMichaelgoode says:
nice
May 17, 2010. 3:54 PMMeganoki says:
really cool!!! i did it ont he first try!!
Aug 18, 2007. 11:23 AMSevereFlame says:
Are you using cheese!?!?! LOL
Apr 19, 2010. 1:04 AMaqwiz says:
 Nope, .. .  'E's usin' COCONUTS!!!
Feb 6, 2009. 2:45 PMbabymama11 says:
they aint using cheese! duh
Jan 29, 2010. 3:03 PMKnexFreek says:
 cool :)
Jun 29, 2008. 4:18 AM=SMART= says:
Here are my attempts :P mine seemed to just get wider as i drew the boxes lol
Oct 31, 2009. 3:29 AMKryptonite says:
Wow nice, looks great if you ask me.
Apr 15, 2009. 12:36 PMqueen roo says:
wow! and you did that with paper?? i never knew....
Mar 18, 2009. 2:31 PMXenel says:
can you post the circle variation and maybe some other shapes?
Jan 30, 2007. 7:58 AMuzerzero says:
I'm loving the fountain pen :) I like doing little tedious things like this to pass time in class, or at work, but unfortunately X-Acto blades are frowned upon at school. If there was a method to do this that didn't involve an x-acto blade, this would be really incredible :)
Feb 28, 2009. 7:27 AMclemsonguy1125 says:
use just 1 blade of sciorrs to cut and it works like a blade
Mar 13, 2008. 1:12 PMfancypenguin845 says:
a metal compass' pointy end works well... just score over the lines and separate.
May 27, 2008. 5:08 PMdata23 says:
How long has that been your profile picture? I THINK U COPIER AUGHGGHGHGHAUFHGHGG (my war cry)
Aug 8, 2007. 8:23 PMthreecheersfornick says:
You can take apart a cheap plastic pencil sharpener for the blade. Then pop it back in when the teacher comes to look at your work.
May 30, 2007. 8:33 PMSmurfJ says:
Well a teacher seeing you in class cutting paper with scissors OR an exacto would be a little worried. What i do is run a regular ball point pen along hte lines over and over again with lots of pressure untill it 'cuts' the paper it doesnt look as clean, but it works!
Sep 8, 2007. 10:16 AMTrebawa says:
When i'm bored in class I do this and it works. When using relatively thin lined filler paper, you only need to push down hard enough the first time and the paper will neatly split.
Feb 28, 2009. 8:59 PMClayton H. says:
Newspaper is easier. *wink*
Mar 21, 2009. 3:30 PMJesus Christ says:
or bring a little razor blade to school and keep your jacket sleeve over your hand? or just use a pocket knife and tell your teacher its for self protection...
May 14, 2009. 3:55 PMstruckbyanarrow says:
self protection... that wont get you suspended at all......
Mar 21, 2009. 5:25 PMClayton H. says:
a guy inventeda marker with a little tiny razor blade in it. could use that.
Feb 4, 2007. 4:13 AMgadgeteer says:
If you fold your sheet of paper down the middle then you can use scissors instead of a craft knife. Fold, make a cut in each end of your foldd sheet, starting at the fold and ending before you reach the oppoite side (because you'll end up with two pieces of paper if you cut any further). Unfold and fold in half 'the other way' and make another two cuts. Repeat from the top with more cuts going towards the center of the paper.
Feb 11, 2009. 7:43 AMbabymama11 says:
this was so much fun i cant believe it. but my cuz showed me a hardr way: get a square peice of paper then cut verticle lines 'bout 1 cm. apart next make horizantal lines then add a little line going down the horizantal lines its juct like yours fungus but its more complicated **how do u make the circle pyramid?**
Feb 6, 2009. 6:49 PMaufachse5 says:
very niec great job
Feb 6, 2009. 2:44 PMbabymama11 says:
this was so awesome to make! out of paper
Dec 2, 2008. 8:22 PMBassystacey says:
Cool! It worked!
Aug 17, 2008. 1:16 PMMetaferia says:
did someone done this in paint or word? it will be much easier and will look nicer. thanks
Jun 29, 2008. 3:56 AM=SMART= says:
Very nice, i like the circle variation too, ill try this now and post pics later :D
Jun 17, 2008. 8:50 PMkenny94 says:
laser cutter + sheet metal and hooks...
Apr 16, 2008. 8:22 PMjonathansmith says:
cool..would really look good on thin metal sheets...hmm..ill try it out and post some pics!
Apr 2, 2008. 12:30 PMmajjck says:
wow, i always wanted to know how they made these. nice job!
Oct 1, 2006. 11:17 AMnoahh says:
nice
Apr 2, 2008. 11:27 AMtigerboy says:
right on
Feb 11, 2008. 12:51 PMUru Wolf says:
I might have to get some sheets of a3 or bigger and try this. I think my OCD is calling, lol.
Dec 24, 2007. 9:06 PMcorradini says:
DUDE, You may be HIGHLY bummed by this comment -- but here goes: I used to make these things when I was, like, 7 years old. And there is a MUCH simpler way: 1. Get a square piece of paper. 2. Fold it along the diagonal (bring one corner over to the opposite corner and crease - you get a triangle.) 3) Fold it again - this time "left-to-right". You have another, smaller, triangle. 4) Now, using scissors, just cut almost all the way through, starting at the top of the triangle, and alternating from left to right with right to left. 5) Unfold the thing and lay it flat. Find the center. Lift. Done.
1-40 of 99next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
1414
Author:fungus amungus(my site)
I like to make things both useful and odd. The odd projects are usually more fun. I'm also the Content Manager here at Instructables. Follow @edabot for more
