3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
"Pop can" Silencer for Nerf Guns
\"Pop can\" Silencer for Nerf Guns
Well, I had seen recently on Wikihow, a way to make a Nerf "silencer" from a can. It was very simple and took me only a little while. I figured I would make an instructable of this, complete with pics.
Here's what you'll need:
- A can (I used a Pepsi can for mine)
- A can opener or sharp knife
- Duct tape (optional but highly recommended)
- Acrylic paint (optional, purely for looks)
Also, a few notes before starting:
- This "silencer" is only aesthetic. It does not reduce the firing sound of a Nerf gun.
- This is not a typical barrel attachment found in guns like the Recon, Longstrike, or Longshot. This will not reduce range.
- If you fit the silencer to any of the Clip System blasters, it will universally fit all of them (excluding the Raider).
Step 1Cutting Holes in the Can
This step is simple. First, all you have to do is cut out the metal on the top of the can using your can opener or sharp knife. Next cut a smaller hole in the other end (you'll have to use the knife for this part), roughly the same size as the barrel of the gun you're trying to fit it to so it will slide over.
8 comments
Jun 26, 2011. 11:07 PMshadow wave rider says:
if you drill a few holes inside the nerf longshot on thebarrel and then place cotton buds or something like that around the hole would that silense the gun?
Mar 5, 2011. 10:02 PMBatryn says:
The reason these silencers don't work is because you don't give air a place to expand well. Also, the hole in front is too big, and might actually act as a megaphone of sorts. I've made one that actually cuts the sound by half, and it uses a small hole in the front, multiple air bleeding holes on the barrel itself, and a way to vent air out through the back in a more controlled manner. This won't work with nerf guns though, because you'd be better off trying to silence the guts.
Sep 25, 2010. 3:07 PMpopscott3 says:
Were did you get the yellow longstrike?
Sep 26, 2010. 8:23 AMpopscott3 says:
Oh rats! it looks cool though!
Aug 7, 2010. 7:10 PMdarknessfalls says:
pretty cool! i personally like the papertowel roll one i made more, but thats only because im sure id cut my finger off working with the can though (LOL!)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Fractal Art
