3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pop can Yo-yo
Pop can Yo-yo
Yo-yo's are fun for everyone. Whether you're just learning or a master full of tricks, yo-yo's put smiles on peoples faces around the world. But wouldn't it be awesome to make one yourself? In this Instructable you will learn how to make one using pop cans and hot glue.
MATERIALS:
Two pop cans
Pencil
Hot glue gun and lots of glue
Roughly 4 feet of string
Scissors
Some sort of heavy duty cutter to cut pencil (I used hedge clippers)
Lets roll!
Step 1Cleaning & Cutting
Cleaning & Cutting
  • last photo ←
First, clean out the pop cans. It's simple, just run 'em under water. Once clean, you need to cut the tops off. To do so, puncture the pop can with one blade of your scissors. Then cut around the can using the hole to start cutting. Once you cut all the way around, you may want to trim the edge. Then do the same process to the other can. Once you have both can tops cut clean, push the drinking hole thingy so it's kinda sealed again. This is so no hot glue gets out. Now take your pencil and cut it so there is a piece that is about 2 inches long. Then set it between the two pop tops so you can make sure that the gap between the tops is ideal. (about 1cm) If not shorten by cutting more. If its not long enough, (though it shouldn't because 2 inches is generally longer) make another that's longer.
22 comments
Mar 9, 2011. 2:51 PMDelo97 says:
Instead of using a hot glue gun, can you melt the hot glue sticks with a lighter? That would be WAY speedier
Dec 6, 2010. 8:43 AMnoonar says:
good instructable
Apr 25, 2010. 9:57 AMseabananers says:
holy crap i can break a pencil with my HAND!
Apr 26, 2009. 4:35 PMshiftnfun says:
is it possible to use two lids for each side? or will it make it too heavy?
Apr 8, 2010. 9:12 PMKing Julien says:
This is too light. There are crazy heavy yoyos that work great.
Nov 19, 2009. 6:11 PMorigamianything says:
is it possible to just use a new pencil, so one end is perfect? And, can you use the other end of the *leftover* pop cans to make a butterfly yo-yo?and, i think on my idea of the butterfly, is it possible to make the ends of the pencil stick out of the center of the yo yo?
        thanks,
        origamianything
Apr 8, 2010. 9:11 PMKing Julien says:
It works!  I used the other ends and made a butterfly yo yo.  It sleeps for 2 seconds and is kinda responsive.  (might post pics)
Mar 28, 2010. 9:16 PMKing Julien says:
I think I will try your butterfly idea.  I'll tell you if it works
Mar 16, 2009. 1:49 PMMaureclaire says:
Can't you get cut on this ? Maybe the cut edges could be folded under ?
Mar 17, 2009. 8:16 AMDoctor What says:
Or, you could fold the metal edges out and make it a weapon.
Mar 28, 2010. 9:17 PMKing Julien says:
nice
Nov 6, 2009. 10:37 AMcerj says:
 This guy made a gameboy sandwich. are you seriously gonna let him near some hot glue and hedge cippers fail.
Oct 3, 2009. 11:55 PMcokecola says:
Try making a yo-yo out of juice bottles. The ones that look like an orange juicer on the inside of the bottom. Build up the sides with some hot glue and paint. They make a cool "big" yo-yo.
Apr 26, 2009. 6:09 PMcookie092 says:
cooooooooool this is so ganna help me with my project....
Apr 13, 2009. 1:58 PMizzy9668 says:
dos it really work??????????????
Mar 16, 2009. 1:35 PMlemonie says:
Don't the metal edges wear away the string? And what's the balance like? L
Mar 17, 2009. 12:30 AMlemonie says:
If I were to have a go at this, I'd consider filling with glue right up to the rim and making the shaft shorter (for better balance)? L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:fearme36
