Introduction: Pop Top Braclet
This instructable shows how to make a bracelet out of the thingys on top of soda cans.
Step 1: Supplies
Get a lot of soda can tops. I'm 13 and I used 14 on this one. I used 17 on my other one so get 25 and you should be okay.
You also need string.
And scissors.
Step 2: Starting It
Put the loop through the top hole as shown in pic 1
Put the 2 ends through the loop as shown in pic 2
Step 3: First One (cont)
go around the sides and down through the bigger hole.
Step 4: Piece Two Side One
put the string down into the smaller hole, around the side to the top, and down through the big hole.
Step 5: Repeat on Other Side
Repeat on other side, and pull tight.
Step 6: Lather, Rinse, Repeat
Repeat steps 4 and 5 until desired length.
Step 7: End It
once it's long enough,put the string down and throug as you would (pic 1)
tie a pretzel knot around the side of the pop top
Step 8: Cut & Youre Done!
Cut off the exess and you are done.
Show off as much as you want.
Step 9: Doubling It.
I just finished doubling it and taking pics, so the 'ible will be up in a matter of days.
