3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Pop-up Dragon Toy
Pop-up Dragon Toy
This amusing toy- sometimes called a "morality toy" when the box is formed in the shape of a forbidden book, with covers, spine and title- requires few hand tools and materials to build. It does however require a power drill and a table saw.
Step 1The dragon's action
The dragon\
I based my design loosely on a simple souvenir sold at the Hong Kong Pavilion at the New York World's Fair in 1964-65.
Also shown is a more elaborate antique carved example in "forbidden book" form, where the more common snake or viper figure is used. It has a wickedly-sharp spike where my dragon features a softer material. Note the wood "binding" on the bottom of the toy (photo credit: ebay user bubbleking)
34 comments
Jun 11, 2011. 9:49 AMapdog4 says:
hmmmm, how did you get that much subscribers with 1 instructable..... xD i dont even have A subscriber
May 7, 2011. 3:12 PMWin Guy says:
Not to pop your bubble, but they have this at my local oriental shop for $2.95 - Thanks for the 'ible, though! Win Guy
Mar 23, 2011. 8:07 PMDenger says:
I had seen plans for a toy like this many years ago in a woodworking magazine, and I've been looking for the plans ever since. Thank you for sharing this!
Mar 29, 2011. 6:02 PMDenger says:
I think the plans I remember had appeared in Fine Woodworking, Wood or some such magazine back in the early 1980s.  It may have been called a "surprise box" (?).  As I recall it, that design was fundamentally the same as yours, (even featuring the dragon, with only slight cosmetic differences).
Mar 13, 2011. 10:32 AMGoodhart says:
I like this a lot. Not just the idea of doing this "in this way" but the mechanism gives me lot of ideas (almost none of which will come to fruition because of time), and because of the splendid detail of the ible itself. Thanks for sharing, and looking forward to more.
Mar 14, 2011. 3:40 AMGoodhart says:
Well, I probably won't "come into my own" until I am able to retire from an 8-10 hour a day job, but thank you. I do try with my limited resources :-)
Mar 12, 2011. 4:31 PMsquirrelMLM says:
Just built it! But I probably spent half an hour longer than I should have:
Couple things:
1. I didn't have a table saw (I'm only 14 years old lol) to make the grooves, so what I did is I took a piece of 1/8 inch plywood the size of one of the sides and cut a second piece into a 1/8 x 1/8 x 3-1/2 piece and a 1/8 x 2-1/4 x 3-1/2 piece. I glued those pieces onto the first original side piece so that there is a 1/8 inch gap in between, making a groove. (hard to explain, see picture)
2. I found that when I drilled the 1/16 inch hole in the center of the dragon, it didn't turn on the nail very well, so I ended up making a 7/64 bit I had, and it turned perfectly.
3. I had to cut a sort of V into the center of the top of the "front end" piece because the string that I had glued onto the bottom of the slide kept crashing into the front end, which stopped the dragon from rising properly.
Overall, a great instructable!
Mar 13, 2011. 10:28 AMGoodhart says:
1. Yes, I was thinking along the same lines because, even though I am 52, I still don't own a table saw (I barely own a hand circular saw LOL). I was trying to think of a way to build a jig, so I could use the ancient hand router I have, but the idea of your way takes less time and effort (always an incentive LOL).
Mar 7, 2011. 1:58 PMRatfink says:
I made one years ago, the mechanics are more or less the same as this one. I built a box approximately 4" x 6", with knob that slides the door open. I used a realistic looking mouse(a cat toy) instead of a dragon, and used a stiff copper wire as the mount. I scared my sister in-law out of a chair with it!!!
Mar 6, 2011. 4:42 PMBubbler says:
I have one of these toys, but it is a snake, and the maker inserted fine copper wire for a forked tongue, which can actually prick a small child on the finger. I could never figure out the mechanism without pulling it apart, so thanks for this Instructable.
Mar 6, 2011. 10:50 AMMark Rehorst says:
This is great! You could modify this by adding one of those electric shockers from a gag pen or lighter. One electrode is the side the box (it would need to be metal), the other is the dragon's tongue. A switch can be arranged to send power to the shocker when you start to open the door. I'd also add a spring to automatically reclose the door when you let go of the box.
You probably couldn't tell the exact source of the shock so maybe just put the two electrodes on the side of the box (fingers touch one contact, thumb the other) and have power turn on when the dragon is all the way out of the box.
Mar 6, 2011. 12:45 PMrbormann says:
I seen one of this when I was really young (long time ago...) and the woodworker that did it explained me that it was made for a psychology lab that was interested in the measurement of reaction under sudden stress. And it was just like yours, but with one single difference. The snake, not a dragon, came out all of a sudden because of an elastic band that was used to pull out the snake. Even if you pulled the cover slowly, the snake would come out quickly, right after the elastic band was taut enough to pull the snake out. That was really uncontrollable and snap like. Sorry for the english, I´m a brazilian portuguese native speaker.
Nice instructable!
I like it very much.!
Mar 5, 2011. 11:27 PMaznbenn says:
Hm... is there any way this could be modified to make it a toothpick holder? like have some way for the dragon to hold toothpicks in its mouth...
Mar 6, 2011. 12:08 PMsrilyk says:
It would be incredibly complicated - you'd basically be doing what a clip-fed gun does with bullets - only with toothpicks. But it sure would be neat!
Mar 6, 2011. 1:48 AMMinifig666 says:
Only afterwards do you realise the dragon wad laced with a deadly neurotoxin...
Nice project, for assassinations.
Mar 6, 2011. 2:23 AMlobo0x7 says:
neat instructable.
there is a way to avoid the table saw for the groove: use and old drawer, wooden box or anything that has allready the channel for the slide. Many drawers has the bottom part living in such slots.
i also tryied with a knife and a metal ruler and it is not so dificult to carve it if the wood is not too hard. if you have a nice thin enough file for finnishing the slot you are all set.
but i picked up last night an old, nice wooden drawer with slots in both sides in the street and it will be just perfect for my dragon box.
thanks
Mar 5, 2011. 2:00 PMAndyGadget says:
Brilliant!
Mar 5, 2011. 1:29 PMbrunoip says:
Awesome, I have to make one of these.
Mar 5, 2011. 12:55 PMBiggsy says:
Kev this is a fantastic I'ble thanks for sharing, can't wait what else you come up with!
High Five for you!
Mar 5, 2011. 10:33 AMAndyGadget says:
I love this - It has an old-fashioned charm to it.
(Any chance of a video of it working?)
Mar 5, 2011. 10:07 AMdragonsniper says:
nice
Mar 5, 2011. 9:53 AMzack247 says:
these are really cool, i remember my parents having one of these, i never could figure it out.
Great instructable!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
20
Author:playfulplans(Kevin)
Author of woodworking plan titles since 1994 featuring plaything designs for adult builders. The All-New Woodworking for Kids (Sterling Publishing, Division of Barnes & Noble), a workbook of basic to...
more »
