Step 3Drill your holes
iImage Information
This step may seem out of order, but to continue with assembly, we need to go ahead and do this. Find a bit for your drill that is slightly wider (1/8 of an inch) than the pole sticking out of the light fixture. Use this bit to drill a hole in the bottom of the popcorn container, as well as one in the side (for the cord). Drill a hole using the same bit into your block of wood. It really doesn't matter if you go all the way through the wood, but make sure the fixture sits in there fully. If you need to make either hole wider, increase the bit size by 1/16 of an inch.
