Popsicle Grapple Hook
325
5
Published
Introduction: Popsicle Grapple Hook
About: I am a really creative person, who loves to build, think , play, act, and more.
In this instructable I will show you how to make a Popsicle grappling hook.
Step 1: Materials You'll Need
You will need;
-6 strong Popsicle sticks,
-3 small and similar beads
-1 long piece of yarn or string.
Step 2: Tools You'll Need
A hot glue gun or any glue you've got.
Step 3: Shape for the Shaft
You'll need a triangular shaft for supporting the other Popsicles, so first make the triangle then glue 2 Popsicles together.
Step 4: Glue the Other Popsicles
Now you may glue the other Popsicles together.
Step 5: Add a Bead
Now add a bit of glue near the tip of the Popsicle, and add a bead. The bead is to help keep the hook part up and not fall down.
Step 6: Add More Glue
Now in front of the bead put more glue and rest the Popsicle against the bead
Step 7: Add Even More Glue
Now add more glue over the tip attached to the shaft to prevent it from breaking.
Step 8: Now Repeat
Redo step 5-7 for all three side of the shaft
Step 9: Now Make a Slip Knot
Now take the yarn or string and make a slip knot. / if you don't know how, then look at the picture/
Then proceed to tighten it along the shaft
Step 10: Make 3 Half Hitches
Bow make three half-hitches almond the shaft these most likely won't come undone.
Step 11: Done
It's a fun toy I use a lot, you can hook it onto a lot of things. Hope you enjoyed!
    • Clocks Contest
      Clocks Contest
    • Pets Challenge
      Pets Challenge
    • Stick It! Contest
      Stick It! Contest
    2 Comments
    I bet if you cut small notches onto the sides of the shaft, it would hold the string even better. You could fit the half hitches into them.
