Step 6Add supports
3 Simple Ways to
Share What You Make
Other ways to share:
Bridge Building Designs
by
abdustin
Teach Engineering: Truss Bridges
by
WYE_Lance
Coffee Cup Popsicles
by
Tin.Man
Leaf inspired bridge
by
antipaxx44
How to Make a Trebuchet
by
howtowithmanish
Popsicle stick coasters
by
Reciclodina
A Mini popsicle stick!
by
vroom...vroom...
how to make a welder for under 5 dollars
by
i_will_carve_your_face
219,557
views
Related: bridge, classic science, triangles structure, posicle stick, popsicle stick bridge, craft stick, craft stick bridge, angles, science, awesome
Comments: 73
Rating: 4.78
All Steps Viewing
Judging Criteria:
The winner is determined by a point system as follows:
Complexity - 10 points : The number of purposeful members involved in the design.
Aesthetics - 5 points.
Engineering - 10 points : How much thought is placed into the design, where the connection points are and what member shapes are used in the design.
Workmanship - 5 points : A bridge that is "clean", such as nice glued edges, members matching at connections and nice sanded edges.
Efficiency - 30 points.
Rolling loads test- 20 points.
If anyone can help please mail me at pravinrox@gmail.com.
Heres the problem statement...
Construct a stable truss bridge of span 20 inches, height 5- 6 inches and internal width 4 inches with hollow and solid members (straws and Popsicle sticks) that sustains a minimum load of one kg.
The deck should be essentially made of straws. The loads will be uniformly/non-uniformly placed on the deck. The bridge will also be tested for its efficiency, rolling loads, complexity, aesthetics and workmanship. Paper (provided) can be used for joints consisting of three or more members.
The efficiency of the bridge will be calculated as follows-
Efficiency = Maximum load sustained by the bridge/Weight of the bridge.
Maximum use of straws is suggested as efficiency will be multiplied by the factor 'Number of straws/Number of Sticks used'.
