3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Popsicle Stick Bridge
Step 9Break it! (Or try)
Break it! (Or try)
  • last photo ←
This is the last step, obviously.
We decided we'd test the bridge with sand in a bucket. We bought two 60 lb bags of sand, thinking surely my bridge would break under 120 lbs.
It held 120 lbs.
We emptied the sand out, and added 40 lbs of water, then added all the sand back. It still held.
We tried the intern, and it still held.
Two days later we bought another 150 lbs of sand. The bridge finally broke under 205 lbs!
How much does yours weigh?
12 comments
Oct 9, 2009. 8:40 AMbradjbear says:
if it is just made of popsicle sticks how does it hold 205 pounds?
Apr 4, 2010. 7:41 PMbassclarinet23 says:
Architectural structure...civil engineering at work.
Aug 2, 2010. 7:53 PMdodo91 says:
i learned about this and the triagles last year.
Dec 7, 2009. 10:16 PMTutublade says:
in my project the weight had to to held with a hook attached to the middle of the bridge. I am scared of the paddle pop stick which the hook is attached on won't hold the weight and snap. help please
Nov 12, 2009. 6:00 PMslimnugget15 says:
 I just made this bridge for my Drafting class (Im a high school senior).  I added cross beams down the center of it for added support so it wont rack from side to side.  I also added a few more various beams in other spots I thought to be weak spots.  My bridge was 20in long, 4in wide and 5 in tall and only weighed 8.5oz.  I have yet to test the weight.  I will post later when I have results.
Nov 24, 2009. 4:13 AMslimnugget15 says:
So I have the results.  I used a 15in board and put it parallel along the top of the bridge and suspended exercise weights from the bottom and it easily held 320lbs and could have done more.  However, my teacher said that was an illegal maneuver becuase the 15in board had to be perpendicular to the top of the bridge so that only 2in of the top of the bridge had all the weight/force on it.  In the end, I retested it and it held and broke at 200lb.  I think hadnt I had the 310lb stress on it before I could have gone higher but hey what can you do.  I set a school record non-the-less!  Thanks for this tutorial!
Oct 14, 2009. 9:21 PMsetayel says:
what is the weight and length of the bridge?
Apr 27, 2009. 9:13 PMDiHydrogenMonOxide says:
I think the key to your success is the clamping. When most schoolchildren do this they use too much glue and weaken the bonds.
Apr 23, 2009. 9:52 AMCamby23mvp says:
I am a science/tech teacher and my kids loved this. I had the students draw blueprints prior to building the bridge. Instead of pop sticks, I used balsa wood. This is by far the best project of the year!
Apr 23, 2009. 12:12 PMcwebsterlusk says:
we did this when i was in the 8th grade only with toothpicks. its amazing how much weight those little things can hold with a little glue.
Apr 23, 2009. 3:20 PMeverywhere says:
i did in 7th grade and it held 20 lbs. designed useing computer
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
125
Author:drinkmorecoffee
I live in a tent just outside of Port Au Prince, in Haiti. Ask me questions. I know the answers.
