3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Popsicle stick guitar
Step 3Making top and back
Making top and back
Glued sticks on a flat surface covered with foil to make top.......the back I glued directly on the Gremlin guitar so it would be arched.........
6 comments
Jun 10, 2010. 4:08 PMmdog93 says:
how did you get the sticks to stay together with such a small gluing surface area. I started gluing the flat top for my matchstick ukelele. I thought i wanted to do this and wanted to do something right there and then, but had no sticks, and didn't have enough time atm for a big project like this. However, i did have craft matchsticks, so i thought smaller sticks= smaller guitar... or a ukelele. I'm thinking i might cheat a bit and brace it with solid wood, because i don't think it will be strong enough. did you double layer? or just glue the sticks side by side and add structural bracing?
Jun 16, 2010. 9:06 AMmdog93 says:
that's exactly as i did, but once removed from the foil it became very flimsy and some of the edge pieces borke of and there was a lot of flex down the middle, i had to re-glue down the cracks where it was weak, but hopefully it wont be too bad. I think i will have to add a lot of bracing to stop it collapsing. It doesn't help that some of the matchsticks aren't perfectfly square and some are completely lopsided.
Jun 4, 2010. 8:39 PMNickoftheRead says:
how did you cut out the central sound hole?
Jun 5, 2010. 10:02 AMNickoftheRead says:
awesome, thanks
May 31, 2010. 6:44 PMjoejoeya says:
neat project.....how were the holes between the sticks on the front and back filled?
Jun 2, 2010. 9:49 AM2105301 says:
wats up joejoeya
wat that mean
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
48
Author:busupholstery
