On "light breeze" days (5mph = 2.2m/s) when most wind generators are becalmed, this light-and-nimble unit reliably generates power, at charging levels, fully taking advantage of the erratic, gusting winds that are so common in near-ground conditions.
A 48VDC, 1,600 rpm brushed permanent magnet motor (#370-350-00 / PE24113G -from a medical centrifuge), with a standard keyed 5/16 inch diameter steel shaft, was used to serve as the generator. A shaft arbor, 3/8-24 right hand (Grainger Item# 3ZN05 / Dayton Item# 3ZN05) was fitted on the shaft, to use as a 12 Volt generator, @ 550 rpm, when turned clockwise. The motor, weighing in at just under 3 pounds, has permanently lubricated bearings, but is not weatherproof.
Note: If you plan to use a counter-clockwise set of blades, the timing of the "generator" brushes (2 carbon brushes) and internal commutator is such that the same amount of power (Amps and Volts) is also generated when turned counter-clockwise, but be aware that the shaft arbor manufacturer's suggestion as to "right-hand" and left-hand" thread pertains to motors only, and not wind generators, where the just the opposite thread is required.
Note that the Grainger Shaft Arbor requires a thin, soft metal shim inserted against the flat face of the standard keyed generator shaft, for the allen set screw (which has a knurled cup point) to bite into and firmly hold the arbor in place. I used 2 layers, fashioned from an aluminum beer can. Or, use a replacement allen set screw with a soft brass core. Also, two, 1-1/4" thin neoprene washers are needed to pad (and grip) the 1-1/4" steel washers that come with the shaft arbor. The original shaft arbor nut was also replaced, with a nut with a thicker profile, with a nylon locking core.
This portable wind generator is ideally suited for one 12 Volt, 21 Amp Hour sealed lead acid battery.
Granted, that's not much power, when compared to typical permanent, stationary wind generators. But this lean-and-mean device was designed to fill in the void, to reliably provide 12VDC power to remote, inaccessible locations.
Remove these ads by
Signing UpStep 1Stock High-Speed Blades for the Wind Generator:
22-3/16 inches long, and designed for a clockwise rotation, when viewed from the front (shaft end), each with two .25" holes spaced at 23mm (25/32") on center. Having only about 1/4 the torque of the much larger Air-X generator, the 17 watt generator spins very easily, in the slightest of breezes.
The blades were mounted on a 5-3/4" diameter, 3/16" thick, ABS faceplate (blade hub), and carefully drilled out to handle either a 3-blade arrangement (as well as a 2-blade arrangement option). The blades were mounted to the backside of the faceplate (hub), to position the mass of the blades as close as possible to the shaft bearings. After bolting the three blades to the ABS faceplate, the tip-to-tip distances of the blades were measured and the blades adjusted with light hand pressure until all three of the tip-to-tip distances were equal, then the blade bolts snugged down.
2 blades are more portable, being easier to stow, protect from damage, and transport, but tend to teeter on the generator shaft, in actual practice. But, after a series of tests, I decided on the 3-blade arrangement, as it provided better performance in low wind conditions (actually typical for many locations).
I fashioned a discarded (actually I'm a hopeless pack rat) thick-walled plastic easter egg ornament into an aerodynamic parabolic plastic nose for the hub, and outline-cut the hub to 4-7/8" diameter, flush with the parabolic nose. The arrangement allows for a smooth flow of air through the blades and greatly enhances the performance of the generator, in low wind speeds.
The Air-X blades, in a portable environment, are much more exposed to rough handling and damage, than they would experience in a permanent installation. A triangle shaped box will soon be built, to carry the blades, hub, shaft arbor and nose, together as one unit, in order to protect the sharp, thin blades from dings and damage, and ease installation onto the generator shaft, in the field.
Thanks a lot,looking forward for your favorable responds..
do i need battery charger or i can directly connect to the appliances.
i want to build portable windmill,can suggest me in order realize my plan without any expenses.?
i want 12V or any suitable for light bulbs only that can able to supply my house lightings.
At what heights are the guy wires attached?
But a good rule of thumb is to place the upper guy wire hook-up as high on the mast as possible.
And for the distance for each of the four anchor stakes from the base of the mast, the guy ropes should be at a 45 degree angle, both from the ground, and the upper guy wire hookup.
But if you're setting up on sand -or on solid ground but with high winds, then 30 degree / 60 degree angles will provide better stability for your rig (30 degree angle from the ground / 60 degree from the upper guy rope hookup).
And for a mast taller than 10 feet, especially a slender, flexible mast, you will need to add a lower guy wire hookup, about one-third to halfway down the mast, and anchor those lower ropes to the same four anchor stakes. The exact positioning of the lower guy wire hookup is best fine-tuned during high winds, carefully observing what position provides the best bracing and rigidity of the mast.
And don't hesitate to add yet a third guy wire hookup, if you're really ambitious and building yet a taller mast than my 15 foot version.
Thanks
But I wasn't wild about the idea of the energy loss in the transfer, not to mention the additional weight, complexity, and maintenance issues that are inherent with going in that direction.
You may have noticed that my devices appear, at first glance, quite simple and obvious. But I prefer to put a lot of sweat, research, and field testing into these things, and generally feel that the end product is worth the time and effort. But none of my projects are never really finished, as I sometimes tend to re-visit them a year or two later and the compulsive tampering process begins anew.
http://www.instructables.com/id/Wind-Turbine-Blades-from-Bamboo/
