loading
Step 6: Attach the Lid (Optional)
If you used a cooler with a hinged lid, skip this step. Otherwise, read on.
By hinging the lid, it makes it easier to open for loading ice and letting air flow in during operation. It also prevents the lid from sliding off and dribbling water out of the heater core while driving. You can use whatever you want for a hinge-a rubber strip glued on, a couple of cabinet hinges, whatever. We used a piano-type hinge that we found in our stockpile of random stuff. It goes all the way across the back, and allows the lid to flip all the way back, but still close completely.
hey there cameronss, love the idea. in fact had to go out and build one myself. i made a couple of modifications to it. i put a vented drain cap on the top and put the fans so they blow on the heater core. the warm air then is blown over the cold heater core thru the chest and out the vent. i also added a little on/off switch to it. i fly on helicopters and it gets mighty hot sometimes, this was the perfect little idea to cool off with. thanks for the idea.
<p>Hey there, where can i contact you to ask for your project?</p>
I was wondering about doing the same thing you are would it be better to blow into the heater core or is that just a theory cause id like to know i want to build a good one for my shop. also i considered using dry ice on those extra hot days to keep the water even cooler. we have a fridge in the shop so ice could keep coming and keep it cool all day. i might need 3 or 4 of these though its like 800 square feet. let me know what you think.
<p>Dry Ice Dangerous!!! pls dont use for home DIY air condition....</p><p><a href="http://dryicenetwork.com/dry-ice-safety/why-is-dry-ice-dangerous/" rel="nofollow">http://dryicenetwork.com/dry-ice-safety/why-is-dry...</a></p>
<p>have you ever heard of punctuation you know the periods commas and capital letters it makes you look so much more legit litter you know able to read and write</p>
ummm dry ice= bad idea for anything like this...it wont work and if you seal up the area, as in to keep it cool inside, you fill the room with CO_2_ which brings about a very drowsy feeling. I know cuz that happened when I purchased Dry Ice one day and got stuck in traffic...and me and my girlfriend had the windows up. And it felt really good but we started getting sleepy.<br/>
You cannot cool your shop using ice that is frozen inside the shop. Ice is water that has had enough heat energy removed for it to solidify. If it is frozen in a freezer, all of the heat energy that is removed (and then some) is dispersed from the coils on the back of the freezer. Since all of the heat is being dispersed back into the shop air, you won't cool anything. Since your shop is stationary, you might as well just get a cheap window unit. It will blow cold air, but all the removed heat will be blown outside, and you won't have to replace ice and water.
it is actually better to blow into the heater core. the fans are more efficient for blowing. i made another one for a guy that worked better when i used a flexible pipe for a dryer. i added another fan to that so that two fans would blow on the heater fan and the added fan would suck that air thru the dryer vent. the dryer vent allows the person to be able to direct the air to whereever you would like. if interested, i could send you some pics of this one. the are a blast to make and if you have a dremel, that will make life easy. thanks for the comment.
Don't let the FAA see it, they'd probably yell at you for it not being TSO'ed. ;-)<br/><br/>I'm glad to see that another person built one, and even more so because it's in the application that KoolerAire was trying to gyp $500 for.<br/><br/><sub>My air conditioner is in a helicopter! Yay!</sub><br/>
in chinook helicopters we have a system that cools water, then pumps it through little tubes in a vest that we wear to cool you down. it works well in an aviation application where you will be sitting not moving for a very long time with lots of ambient air blowing all around.
Woohoo! I just bought my ice chest to start mine and have the fan mounted so far. My first one will be cooling my 86 Accord for the 95+ days in Sac, CA. The second will be a gift for my father-in-law for his almost completely restored 1969 Nova. Target has a really nice cooler that has a "compartment" in the top for cell phones, keys, etc. This compartment works perfect for a 4.5" muffin fan. When mine is complete, it will still look like an off the shelf cooler. Go to target.com and search for "Igloo Ice Cube 14-qt. Cooler ". Hopefully mine will be completed in a week or so. (wish I had it today.... 101 forecast!!!)
Just went to check something on my ice chest and it looks like Target.com doesn't have it anymore. The one that comes up as the Igloo Ice Cube is 17" cubed. Mine is only about 12" cubed. It looks the same though........ I put all my parts together and ran a test. With 4 cups of ice and about a gallon of water, the air coming out was 58 degrees. As soon as I finish modifying the heater core (soldering on elbows) I'll post pictures and maybe an instructable.
Picture! Picture!
Still prototyping, but here is an idea. Ford Escort Heater Core: new at Kragens for $40, shown with the ends cut short and elbows soldered on Attwood T-500 Bilge Pump: $17 at Walmart ComAir Muffin Fan, 12V, 102CFM, Free from the garage Igloo Ice Cube 14qt ice chest: $15 at Target Heater hose: free (going to change to vinyl tubing for flexibility) Rocker switches: free from garage, one for pump, one for fan AC Adapter for Testing, 12V, 4.5Amp: from the workbench So I am into this for $72 so far, but I am buying most items new . Hoping to finish by the weekend.............
<p>Hi there,</p><p>I just purchased Mini Compact Air Conditioner</p><p>for my personal use. </p><p>I read fron this blog http://buytopreview.com/mini-compact-airconditioner/</p><p>and the product is really great.</p>
<p>Maybe this will make sense... What if you had one fan blowing through the core into the truck, and one blowing through the core into the cooler? This would allow for return air while cooling it before entering the cooler allowing it to stay cold longer, and cool the truck off. Just an idea, think it would work?</p>
I was thinking the same thing as I read the instructions. It would require a little extra wiring but making one fan reversible would allow you to perform a recirculate function after a couple minutes of initial cooling.
<p>This instructions are good but do you think it is needed now a days. There are a lot of 12v air conditioner offered by manufacturer with safe and long lasting performance. A piece of good advice &quot;higher prices generally mean better quality since quality doesn&rsquo;t come cheap&quot;. So do not try to invent which you do not know for safety reason. But for school project it is good, this information or content would be the foundation for those students who have broader knowledge to developed and update our air conditioner for the new generation to become affordable with good quality. Alike portable 12v refrigerator maybe now this fridge is not cheap and affordable. Thanks to this concept.</p>
There are many products that are manufactured that are priced too high with extremely low quality. For example, Pioneer has a 6.75 inch speaker for around $200. Each And they have a pair of speakers for $24. It would seem that if I listened to you then the first speaker might be the better choice. But if you also don't understand frequency response then you might like the more expensive choice. The higher priced is 150hz. - 6,000hz. For $200. each while the others are 32hz. - 40,000hz. for $24 a pair. The higher priced is nothing more than a glorified mid-range speaker. The lesser is a full range speaker with bass you can feel and with extreme clarity. <br><br>Not all brand name items are worth the money. Learn to shop with specs. and know what you are buying. <br><br>When most people can't find what they are looking for at the prices they want, then they fabricate. <br><br>An Inventor or a Fabricator with engineering skills and education will research and research again to solve problems and find the best solution. And prototypes are tools of discovery.
If i want to use this for camping. What battery should i use?<br>
<p>That's a great idea! Having AC is so important, especially during the summer. No one likes to be miserable in the unbearable heat. The only think I would worry about is having the water spill out of the cooler. Has that been a problem before? http://fan-guy.com/?page_id=1281</p>
<p>Nice blog. We would be happy to use your service. Its really important to find a customer centric company for &lt;a href=&quot;http://myaircontrolsolutions.com/&quot;&gt;AC installation service in Houston&lt;/a&gt;. Your blog is really helpful to me to give a light in that issue. Thank you.</p>
<p>I'm not understanding what the heater core is for. Can somebody explain</p>
<p>I'm giving some serious thought to rigging a unit like this up in my truck (hasn't had working AC since the late 90's). The cool thing is that there's an easily accessible vent in the dead center of the dash that's also right above the only clear and easily accessible spot where I could put something like this. With a little bit of messing with duct and fan sizes, it doesn't seem like it'd be to hard to get cold air flowing out of one of my vents at least. I really like the idea here, man.</p>
<p>I am in the process of building this cooler-- so far so good. I am using 2 120mm cooling fans but they have very small caliber wiring that uses a 3-pin connector. How do I connect those to my bare wire bilge pump and my cigarette lighter plug power source. Thanks.</p>
<p> hey guys here is blog on how to build an A.C. stepwise explained. it is low cost and free of danger. http://blogforeverythingyouwant.blogspot.com/</p>
<p>I just ordered all of the materials for this project. I have read about both methods of placing the fans. Can anyone tell me as to which method actually works best? Blowing air out of the cooler or sucking air from outside?</p>
<p>I just got all my materials for this, too, and was wondering the same thing. I think I'm going to put a dryer vent on the top that can twist in either direction and have the fans pulling in air from the outside. It seems like there would be less evaporation to ware out the fans this way. Let me know what you ended up doing, please! I'm curious :)</p>
<p>This does work but why not simplify it, 2 holes, 1 fan, and just a cooler full of ice works 100% the same.</p><p>★★ Signature: &trade; <a href="http://trydeal.com" rel="nofollow">007 Hiding Car &amp; Motorcycle License Plate Gadget</a> &trade;★★</p><p>.</p>
<p>So I'm going to make one of these for two reasons, one because my room has a lot of computers and electronics in it and it's on the west side of the house so it gets stinking hot in summer (Down here in Australia the sucks) and also because the aircon in my car is broken and I'm too cheap to get it fixed. My question is, wouldn't you be able to put the heater core and the fans outside the esky (Cooler to you guys) with the hoses running in, that way having the unit where the water is completely sealed? I'm clumsy and I don't want water going all though my room, also the road where I live is rough and my ute has really hard suspension so the ride is shocking (No Pun intended) Just a thought, it should work right? </p>
<p>another thought, you could use a blower fan that cars used to push the air, it'll move a lot more air and cool the place down quicker</p>
<p>Desert coolers is what they are called in some parts of the world</p>
<p>Quick Question:</p><p>Would it matter if we use a container other than an ice box? I mean we are venting out air at a fairly quick pace. I don't mind portability as I am planning to use it in a room. Pls do reply, </p>
PLASTICBALDY, DIDN'T KNOW THIS WAS ENGLISH 101. I did this as an instructable, something to do on my own, if you don't like the &quot;English&quot; then don't read it.
<p>I think plasticbaldy was referring to some other person's comment. Don't worry mate, I find your English perfect! So is your project</p>
<p>Um, you are using fans and coolant. Wouldn't it be more efficient to just use a refrigeration system? Instead of buying ice, which takes a lot of energy to make, you could use a normal refrigerant based unit. That way, you never have to replace the coolant. You know, a fan, a condenser, a heat exchanger, etc... Seems like you are doing something here that uses the same amount of energy to cool air as other things that cool air way more efficiently. </p>
<p>If you're going to do that, then you may as well buy an aftermarket cooling unit and have it installed in your vehicle. Not exactly portable though - can't take it from one vehicle to another (or use it in your plane or copter or tent for that matter).</p>
<p>I think it's a little unfair to say it's cheap, when you have half the products &quot;on-hand/used&quot; but I will build this and you did give me an idea. I'm sure someone in my large family might have some of the parts to make this an easy build.</p>
<p>Would it be worth while to build this into something like a zeer pot <br>refrigerator thing? You mentioned that the air was drier in the truck <br>after running a bit, and since the zeer pot functions on evaporation <br>concept, I was wondering if that would help the ice to last longer and <br>the whole thing cool longer?</p>
<p>Would it be worth while to build this into something like a zeer pot refrigerator thing? You mentioned that the air was drier in the truck after running a bit, and since the zeer pot functions on evaporation concept, I was wondering if that would help the ice to last longer and the whole thing cool longer?</p>
hey i know this is quite late, but how do you even get air for the vent to work? isnt it building up a vacuum inside the box with no holes for air?
<p>tom_fl... please re-read the instructable. It states you need to leave the top open a litle to vent (the author said he flipped back the handle and that worked fine) I made this unit once for fun out of scrap parts and I drilled a 1 inch hole close to the top on the side of the cooler and was able to cover it with some plastic mesh and glue to allow air in and keep critters out and keep the lid closed! Worked great!</p>
<p>Here is a use for this super cool idea that few people will have .... my father (78 years young) has a 1964 Combine he uses every year around July. He is harvesting fescue seeds. Combines are VERY expensive and it doesn't make sense to purchase a new one for the small amount of harvest that he has. There is no AC in this huge machine and there is only one large window. This is the perfect solution! Thank you from a eighth generation farmer! </p>
About This Instructable
1,471,602views
1,477favorites
License:
More by CameronSS:CameronSS's Convertible Cross-Campus Cloister Synchronize Pidgin Logs with Dropbox Sugru Precision Pencil Grip
Add instructable to:
