Portable 12V Air Conditioner --Cheap and easy!
This project is my dad's $10 solution to a $500 solution to a $25,000 problem. As I have previously mentioned around the site, my Dad owns an electric 1979 Ford Courier pickup, and is cool enough to let me drive it around. We absolutely love it, and wouldn't trade it for a Tesla Roadster, but one of the few problems with electric cars is heating and cooling. In a gas car, heat is provided by the 80% of the gas that is wasted as heat, and air conditioning is provided by a crankshaft-driven compressor system. Many EVs use hair dryer elements and fans for heat, and some, ours included, feature a powerful gasoline-burning heater.
(Update from 4-22-08: I'd forgotten that I mentioned the gas heater on here. Last fall the gas tank and heater were removed, and a ceramic heater was built in. It works great, although not quite as fast, and doesn't use gas.)
However, air conditioning is trickier because the shaft of an electric motor doesn't always spin. Some have used a compressor driven by the motor shaft anyway, while others have turned a compressor using a separate motor. Finally, my dad came up with part of the concept for this system. It pumps ice water through an evaporator core, which has fans that blow air through it. It is very simple, but we found what we were looking for at Sporty's Pilot Shop. They sell air conditioners built into ice chests for prices ranging from $475 for a basic model to $625 for a 24V, dual fan model.There is also an ArcticAir unit for $4750 with a full compressor unit. However, we like our $10 version better. I saw the ArcticAir display at EAA AirVenture Oshkosh this summer, and our unit is more compact and puts out cooler air. All you need is materials, basic construction/assembly and wiring skills, and a bag of ice. Let's go!
Update, 5-12-08: 100,003 views! Yay! I'm no Kipkay, but I'm still proud.
Step 1Background and How it Works
This project is very similar to the ArcticAir Package Unit. In fact, I attached two pictures of it I took at AirVenture this past summer. It looks almost identical to ours, and we built this without ever seeing a picture of the inside! The basic concept is to use a boating bilge pump to circulate iced water through a heater core, then use 12V fans to blow air through that core, which cools the air and pulls out water through condensation.
Advantages: Very compact and portable, lightweight without the ice, no environmentally not-so-friendly chlorofluorocarbons, hydrogenated chlorofluorocarbons, or hydrofluorocarbons, very quiet, and operates off 12VDC, AKA a cigarette lighter. The only disadvantage is that it the ice will melt after 30-60 minutes of operation, depending on the size of your cooler. However, it was built for an EV, so we are only ever out for an hour or two maximum, and the ice lasts longer when it's not running. The third image on this step shows the operation. Have I convinced you to build one yet?
537 comments
1-40 of 537next »
May 15, 2008. 12:51 PMawawawaw says:
Woohoo! I just bought my ice chest to start mine and have the fan mounted so far. My first one will be cooling my 86 Accord for the 95+ days in Sac, CA. The second will be a gift for my father-in-law for his almost completely restored 1969 Nova. Target has a really nice cooler that has a "compartment" in the top for cell phones, keys, etc. This compartment works perfect for a 4.5" muffin fan. When mine is complete, it will still look like an off the shelf cooler. Go to target.com and search for "Igloo Ice Cube 14-qt. Cooler ". Hopefully mine will be completed in a week or so. (wish I had it today.... 101 forecast!!!)
May 19, 2008. 12:09 PMawawawaw says:
Just went to check something on my ice chest and it looks like Target.com doesn't have it anymore. The one that comes up as the Igloo Ice Cube is 17" cubed. Mine is only about 12" cubed. It looks the same though........ I put all my parts together and ran a test. With 4 cups of ice and about a gallon of water, the air coming out was 58 degrees. As soon as I finish modifying the heater core (soldering on elbows) I'll post pictures and maybe an instructable.
May 19, 2008. 11:14 PMawawawaw says:
Still prototyping, but here is an idea. Ford Escort Heater Core: new at Kragens for $40, shown with the ends cut short and elbows soldered on Attwood T-500 Bilge Pump: $17 at Walmart ComAir Muffin Fan, 12V, 102CFM, Free from the garage Igloo Ice Cube 14qt ice chest: $15 at Target Heater hose: free (going to change to vinyl tubing for flexibility) Rocker switches: free from garage, one for pump, one for fan AC Adapter for Testing, 12V, 4.5Amp: from the workbench So I am into this for $72 so far, but I am buying most items new . Hoping to finish by the weekend.............
Aug 29, 2008. 9:37 PMrbfe4ch47 says:
hey there cameronss, love the idea. in fact had to go out and build one myself. i made a couple of modifications to it. i put a vented drain cap on the top and put the fans so they blow on the heater core. the warm air then is blown over the cold heater core thru the chest and out the vent. i also added a little on/off switch to it. i fly on helicopters and it gets mighty hot sometimes, this was the perfect little idea to cool off with. thanks for the idea.
Nov 11, 2008. 4:52 PMmetaljoe0 says:
in chinook helicopters we have a system that cools water, then pumps it through little tubes in a vest that we wear to cool you down. it works well in an aviation application where you will be sitting not moving for a very long time with lots of ambient air blowing all around.
Jan 9, 2009. 7:12 AM03CR250 says:
I was wondering about doing the same thing you are would it be better to blow into the heater core or is that just a theory cause id like to know i want to build a good one for my shop. also i considered using dry ice on those extra hot days to keep the water even cooler. we have a fridge in the shop so ice could keep coming and keep it cool all day. i might need 3 or 4 of these though its like 800 square feet. let me know what you think.
Jan 9, 2009. 9:56 PMrbfe4ch47 says:
it is actually better to blow into the heater core. the fans are more efficient for blowing. i made another one for a guy that worked better when i used a flexible pipe for a dryer. i added another fan to that so that two fans would blow on the heater fan and the added fan would suck that air thru the dryer vent. the dryer vent allows the person to be able to direct the air to whereever you would like. if interested, i could send you some pics of this one. the are a blast to make and if you have a dremel, that will make life easy. thanks for the comment.
Apr 27, 2009. 5:17 AMxvitox says:
ummm dry ice= bad idea for anything like this...it wont work and if you seal up the area, as in to keep it cool inside, you fill the room with CO_2_ which brings about a very drowsy feeling. I know cuz that happened when I purchased Dry Ice one day and got stuck in traffic...and me and my girlfriend had the windows up. And it felt really good but we started getting sleepy.
Nov 5, 2011. 11:16 AMhagrawal3 says:
hey i have also made an a.c. com. heater and it works great!!!!!
DSCN1632.JPGDSCN1633.JPGDSCN1634.JPGDSCN1635.JPGDSCN1636.JPGDSCN1637.JPGDSCN1638.JPGDSCN1639.JPG
Oct 23, 2011. 7:42 AM2be994510 says:
CameronSS: Nice work! I have read most of the comments and found them interesting. We are in the process of building the unit now with some modifications. If it works well then we will go to a larger system. Best wishes from Thailand
Sep 19, 2011. 11:43 PMdeac02 says:
If creating ice is a problem and not green why not build a solar ice maker. Add in a solar charger for the battery and bang, boom it is almost self sufficient. Cool.
Sep 14, 2011. 1:48 PMtwarner1 says:
The alternative to having this machine is having the existing AC fixed, which costs not only much more money, but is also more harmful to the ozone. A oil fueled Chlorofluorocarbon machine in essence!
Sep 5, 2011. 1:27 AMironjudas says:
Dry ice cant be put into water it will dissolve in seconds. Btw, do you need to keep supplying it with ice?
Aug 31, 2011. 11:38 AMDIY Dave says:
Sorry if I missed something, but how do you keep the water from splashing into the fans?
Aug 31, 2011. 1:57 PMDIY Dave says:
Thanks for the quick reply
Aug 31, 2011. 7:57 AMshowbizkid83 says:
Can dry ice be used as a cooling tool.
Aug 27, 2011. 10:02 PMguitaristjosh83 says:
i could probably find the answer to my question if i were to go through and read every single comment... but can you please tell me a quick and easy answer? should the fan(s) blow down through the heater core and into the cooler, forcing air out from under the cooler lid, or should the fans blow upward away from the cooler, sucking cooled air that passes through the heater core? i need to know which works best (not in theory, but in actual use and testing) before i build mine. thanks.
Jul 31, 2011. 6:16 PMHunter Wolf says:
Question: Would this cool a 10x10x8 (LxWxH) foot room?
Jul 16, 2011. 10:54 PMasiddiqui attari says:
What shall be the size of heater core and whether it should be a 1line heater core or 2 line heater core.
Is there any substitute for heater core?
Aug 16, 2007. 5:05 PMtazz1781 says:
While its a great project, its not all that green. For example, where does the ice come from? A machine that produces heat to make Ice and uses harmfull gases to do so. So, for the continued cost of the ice, whether buying it daily or having your ice box run more so you can provide your own ice, your really not saving any money or the enviroment.
Aug 5, 2011. 12:40 PMlloydrmc says:
...and which "harmful gases" might those be, and in what way are they harmful?
Aug 4, 2011. 5:33 PMlloydrmc says:
My "ice box" runs more? How much more would that be?
And agritzmacher has a point - how do you think electric cars are charged?
The raw materials and manufacture of Prius batteries requires 10,000 miles of transport, literally across the world: http://www.carkb.com/Uwe/Forum.aspx/car-driving/9345/A-Prius-Causes-More-Pollution-than-a-Hummer
Virtually all CFL bulbs - which we will be required to buy soon - are made in Chinese factories, fueled by "dirty" coal power plants. And they contain mercury, which, if the bulb breaks, requires approximately 6 types of tools and materials, and 14 steps (including cutting out a section of your carpet, if that's where it broke) - depending on who you ask.
Aug 4, 2011. 7:52 PMlloydrmc says:
Do YOUR research!
Point 1: Power plants in China (where virtually all CFLs come from) are NOT in any way shape manner or form: "cleaner than power from a gasoline engine". They have no scrubbers or any other type of pollution control whatsoever! In some Chinese cities, the smoke from power plants and other pollution literally makes it difficult to see for any distance, even at midday. http://news.nationalgeographic.com/news/2007/07/070709-china-pollution.html
Point 2: Try actually reading my comment. My comment was NOT about the impact of mercury on the environment in general but rather what a nightmare it is to have to clean up after a mishap with a CFL that we are going to soon be FORCED BY LAW to purchase, e.g.: http://www.maine.gov/dep/rwm/homeowner/cflreport/appendixe.pdf
Have you ever actually used a high-lumen CFL (such as a replacement for the soon-to-be-outlawed 100W Edison bulb)? It is recommended that they only be used in applications where they will be on for at least ten minutes, because it takes 5+ minutes for them to reach rated output
Jul 31, 2011. 11:19 AMagritzmacher says:
The same reasoning can be applied to electric vehicles plugged into the electric grid to charge... Just sayin'
Aug 16, 2007. 6:05 PMtazz1781 says:
Yes, the ice box runs regardless, but it runs more to freeze water. How about using solar panels to run your portable cooler, or to charge the battery? Then you would have a somewhat "Green" portable AC.
Jun 3, 2010. 9:15 PMjpnagle59 says:
Cameron-- I live in Texas, Waco Texas, and so far this 'spring' we have hit 101 and 102 in my area. I have a 1993 Honda Civic, 200,000 miles on it, and the air is/has been gone now for a year and a half. This is one of the most brilliant ideas I have ever come across. Hat's off to you and your Father. I am late on this in terms of 2007, but I have a question if you could take a stab at it, I would be most grateful.
Do you think this design will cool a 4 door Civic to a comfortable level here in Texas when it is 100 outside? I suspect we would go harder on the ice, ie, it will melt quicker, but I am an older disabled person that has a harder time as I age with the heat. I sure would like to hear what you have to say to my questions.
I also wanted to say that I know the head of the physics department at UT Austin. I am going to ask him if there is a way to add something to the water to make the ice/cold last longer. Without using salt, and non-corrosive to the heat exchanger. If he gives me a good answer, I will let you know. one more thing- may I have you and your fathers approval to build your idea??? Tahnks so much, james
Jun 8, 2010. 9:57 PMjpnagle59 says:
Thank you CameronSS...hats off to you and your father...
Jun 7, 2010. 9:39 PMbmlbytes says:
The CC license he attached to this instructable would indicate that you were allowed to build this, and to modify it to your own needs: "This license lets others remix, tweak, and build upon your work non-commercially, as long as they credit you and license their new creations under the identical terms. Others can download and redistribute your work just like the by-nc-nd license, but they can also translate, make remixes, and produce new stories based on your work. All new work based on yours will carry the same license, so any derivatives will also be non-commercial in nature. "
Jul 25, 2011. 12:50 PMrhighpointer says:
Question:
I have the same exact bilge pump used in the instructions, and two 12v DC 120mm fans. My system is simply not getting enough power. I have the wires running into an old cell phone charger. When I take the bilge pump out of the water, the fans start. The second I put the bilge pump back in the water, they shut off. Is the plug that I am using the problem? I have tried splicing off of three different old chargers I have, all to no avail.
1-40 of 537next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
97
Author:CameronSS
I'm a geeky college student without enough free time or funding to do most of these Instructables...sigh... Topeka is my hometown. I'm at school in Wichita about 80% of the time, but I like Topeka be...
more »
