Introduction: Portable A/C
Picture of Portable A/C
This is a presentation for making a battery powered Portable A/C.
Step 1: Spray Foam Box Fail
Picture of Spray Foam Box Fail
We started by spraying spray foam into a plastic box that will hold Ice,with no research on what spray foam sticks to. When we sprayed the foam into the box it looked great. When we came in the next day we found our project a mess. We researched spray foam and found out it doesn't stick to plastic. So, we got rid of the plastic box idea and built a plywood box, and used pink foam insulation squares to insulate the box. We then covered the pink foam with layers of silicone caulking, which sealed all the holes and air gaps in the box, as well as adding an extra layer of support on the insulation.
Step 2: Layout for Ice Box
Picture of Layout for Ice Box
Measure plywood for dimensions of Ice Box that will measure 1', 1', 2'. Then we used a chop saw to cut the pieces out of plywood, and after that we drilled 3 holes in the front of the box for the cold air intake to go into the box, and then one hole on the back of the box for the exhaust of the even cooler air.
Step 3: Designing Ice Box
Picture of Designing Ice Box
Went to design a 3-D model of the Ice Box through solidworks, this was the step by step design process. The box is designed to be both lightweight and easy to use, but within a decent price range.
Step 4: Step 4
Picture of Step 4
here is the ice box that will be mounted to the back of the ac to make the a/c a tow way cold air system. Also mounted on the box is the 12 volt to 120 volt inverter where we bring 12 volts in on a power tool battery
Step 5: Step 5
Picture of Step 5
To finish the box we will insulate the top piece of the plywood cover with foam and make the top of the box removable for ice to be placed into
Step 6: Step 6
Picture of Step 6
We finally hooked up the AC to the box, and let it rip, it proved to blow cool air out the exhaust side so no warm air was being blown around. Also included are pictures of the rare Danny nebula having a snack break
Step 7: Fixing the Issues
Picture of Fixing the Issues
We started the ac up, and the water from the melting ice was leaking out of the bottom of the box, so we rubber cemented around the bottom of the box and it sealed it up, we also found there is a substantial draft where the ac and the box connect, so we have to seal that up.
Step 8: Temperature Reading
Picture of Temperature Reading
We used a fluke digital thermometer to measure the temperatures of the air coming out of the regular air side of the ac and the air coming out of the ice box, the temperatures were 58 coming out of the regular ac and 44 coming out of the ice box side. The temperature of the coil blowing the exhaust air into the ice box was 100 degrees.
Step 9: Electrical
Picture of Electrical
We Installed a 12 volt to 120 volt inverter on side of ice box to be used on most job sites on batteries including drills.
Step 10: Conclusion
Picture of Conclusion
Overall our portable A/C worked when it blew cold air out of both sides
the Oracle of Ampersand (author)2016-05-13
couldn't you have simply drilled through the side of a chest cooler and mounted the inverter to the side of the cooler? holes could be drilled into the lid for your warm air intake, and a small fan(perhaps out of an old pc) could be mounted over the discharge hole in the side of the cooler for cold air output. perhaps some baffles would need to be installed to direct airflow from warm to cold ports, but it seems that this would save steps and labor without reducing the effect of the final product.
About This Instructable
699views
8favorites
License:
More by Wolverine1997:Portable A/C
Add instructable to:
