It works on a car's cigarette lighter, with two easy to find computer fans and a common cooler. It took me a couple hours to make, and that was including the failures that you don't have to suffer through, thanks to this guide.
Remove these ads by
Signing UpStep 1Get cooler, "fix" it.
The first thing I did was use a Dremel to remove the lid (keep this, you'll need it). Then I cut two square holes, one in each side of the cooler, for mounting the fans. I already had two different sized fans, so I made different sized holes.
www.instructables.com/id/Too-Hot-Remove-heat-from-your-body-with-the-Back-/
