3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable Altoids Speaker System
Once I saw the dead computer contest, I finally thought of a use for all these little speakers I had been collecting out of dead computers at work.  This is fully functional, however, I need to tweak the speaker setup as they are all currently in parallel and do not produce enough sound.  I will probably change this so that it is a combination of parallel and series.
Step 1Tools and materials
MATERIALS
Altoids tins x3
1/4in id copper pipe
3/8 brass T compression fitting x1
3/8 brass Union joint x3
2.5mm mono jack x4
2.5mm mono plug x4
Assorted wire
Assorted speakers that fit in altoids tins
3.5mm stereo panel jack x1
4 slot terminal strip
Heat shrink tubing
Zip ties
TOOLS
Soldering Station/Iron (and solder, obviously)0
JB Weld
Ruler
Drill/Rotary tool
Hacksaw if you don't have a rotary tool
Needle files (also called precision files)
Phillips screwdriver
Acetone
Toothpicks
Q-tips
Miniature pliers (needle nose, flat nose, angled dykes)
Pipe cutter
11 comments
Mar 4, 2010. 7:31 PMdigimancer says:
 Use different housing for the altoid boxes and this could be a steampunk submission.
Jul 19, 2010. 10:40 AMsway says:
I agree with digimancer. With just a small bit of creative touch up, this is an awesome steampunk item. Also wondering if you have travled with this yet. I suspect airport security is going to have a field day with this.
Apr 27, 2010. 2:31 PMdigimancer says:
 lol
Jun 1, 2010. 5:01 PMCeiling cat says:
Sounds like you have a great job.  Where do you work?
Jun 3, 2010. 3:31 PMCeiling cat says:
What do you do there?
Mar 4, 2010. 3:14 AMComputothought says:
Had to use "The gimp" to lighten up the pictures to see them.
Mar 4, 2010. 8:29 AMComputothought says:
Cool....
Mar 4, 2010. 3:25 AMComputothought says:
Modded pic.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:irishlyrucked
