Step 2Wiring things up.
Now, this amp in particular, takes a 120V current from the houseline, and steps it down to 13v for use with the amp. However, I am lazy, and don't really care what happens to this amp, so we're just going to completely bypass the stepdown converter, and hook up a sheer 18v directly to the mainboard. It's all solid state, so the worst that'll happen is a battery might explode, or you'll burn out the ICs. Hope you don't want this amp anymore.
So, basically, what we'll do, is wire the two batteries in a series, attach the negative to the mainboard, and the positive to a switch (because we're bypassing the built in switch). And that's pretty much it, as far as wiring goes. To wire two batteries in a series, attach one positive terminal to the other's negative, and then use the free positive and negative terminals to attach to your actual destination. I find that the little 9v battery clips are the easiest way to do them, although I could only find one of them when I did this project.
Add Comment
