The objective here is to build a portable guitar preamp that I can carry around and gig with different people. It can also replace the preamp section of my guitar amp, which is a Peavey, and borrow the sounds of Fender/ Marshall/ Vox from its tonestack.
Remove these ads by
Signing UpStep 1Schematics
http://www.redcircuits.com/Page120.htm
I then borrow the tonestack from the Tonemender that is found at www.runoffgroove.com . The Tonemender is a booster with a very flexible tonestack, which can re-create the Fender, Marshall and Vox responses.
http://www.runoffgroove.com/tonemender.html
Details of these schematics can be found at the links above, which explain clearly what these circuits do and how they work.
and better labels of what the component are(Like value of resistors and cap.)
where do the transistors go ?
thanks for the input..
Why not up the voltage from a single cell? Or run at 9v?
The tonestack is the section I highlighted in red in the new photo. This is the part that shape the sound.
If you look at the Blackface's circuit, coming out of the 1st set of transistors, the signal goes into the tonestack, then the signal goes to the vol (P4) with or without the C6 (bright switch) to enter the 2nd set of transistors.
So instead of going into the original tonestack, in my version, the signal comes out of the 1st set of transistors to the Tonemender tonestack (the red part), then to vol (P4) and the 2nd set of transistors.
If you look at the Tonemender circuit again, the signal comes out of the 1st opamp, then into the tonestack, then into the 2nd opamp.
So if you look closely, both circuits are actually doing very similar things.
The tonestack is totally passive and it does not use any power. Vref in the Tonemender = Earth = 0V. Hope it helps!
In a couple of days I'll start to work on it. I'm interested on make a bass version, so I need to tweek the voicing in the tone section and some caps here and there, you know.
Thanks again for your kindly response!
I let you know as soon as I get positive results.
Cheers!
The guy at the store gave me the stereo plug , how do i wire it for mono ?
Ill post the link to m 'ible as soon as it's up.
P.D: Cool project, could you upload some videos or sound to have a listen on it???
Looking forward to your instructable!
P.S.: I will try to get some sound clips when I've got the time.
for the big amount of gain you can remove the C8 cap and put the Jfet buffer like on the red circuit page,
just replace the output résistor by a 100k log pot and you get a master volume.
http://zonaelektronika.blogspot.com/2010/06/direct-injection-box-for-recording-pa.html
Getting back to the original question: Could you wire an XLR connector in somehow and use this as a Direct box?
The signal from this preamp is unbalanced, so it cannot be used as a DI just by changing the wiring. However, an additional circuit can be built it to add that function, but then it is like putting a DI after this preamp. In that sense, I would choose to build a separate DI instead for its portability and usability.
Yet, it may be possible to build a DI with the same tonestack built in, which I think would be a better option.
A nice active DI circuit can be found at: http://www.muzique.com/tech/opamp_multi.htm
A preamp and an active DI are basically the same thing. So, conceptually, it should work. The op-amp version of this should work for a mic, but I don't know about the transistor version (I'm not that good at circuits yet).
