3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable HP Washing Machine
This is a washing and wringing combo device.  Please note the "Machine" part of this washer is mostly your body, arms and back, etc., so if it hurts to lift a bucket full of wet clothes and water, first ask a friend for help, or just stick with the electrical powered washer.
Total project cost $6, assuming you have a hammer, razor blade, and one nail.  It's as easy as hammering a nail through plastic and takes less than a hour to complete.
Safety note: razor blades are sharp, dangerously sharp, always try to cut away from yourself.  I suppose you should be careful with the hammer too.
Step 1Materials
Materials
These are the base materials found at your local hardware store.
1: Bucket 5 gallon. $3  If you have a spare bucket laying around you can use it, I've seen what I put in my spare buckets and chose to buy a new one.  There was a bright orange version of this bucket that I didn't get because I like white better and it was a dollar cheaper.  You can also reuse a kitty litter bucket.
2: Good Lid. $2  That is the orange one.  It came with a rubber gasket on the inside cover, very useful for keeping things water tight.  The first washer I build used the cheap lid below and it leaked if you turned it upside down.  The orange lid does leak no matter which way you turn it.
3: Cheap lid.  $1 This the lid that came with cheaper white bucket I liked better, leaks like a sieve when upside down, but that's good because I used to make the wringer.
3 comments
Sep 25, 2011. 9:44 AMrmiller18 says:
why not use a second bucket for the wringer perforate the bottom it .Put it in over the clothes ,flip both over and sit on it to wring
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:wbarrett
