3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable Keg Cooler (a.k.a. R2-Beer2)
Step 4Drain and Bottom Support
Next, assemble the drain, reducer, and elbow. Mine came out to just over 4" tall. To allow room for the drain as well and insulate the bottom, the inner barrel will need to be elevated.
Cut two pieces of plywood to the appropriate dimensions to fit inside the big drum and make a nice sturdy "X" with a couple of cuts in the center. I added 2" x 2" chunks on the side to hold everything together, but that isn't really necessary.
Check for size and start cutting the foam board to fit the spaces between the supports. Once everything looks good, put the small drum inside and mark the hole for the drain. Mount the drain and check everything for fit.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:glubash
