Portable Metal Bandsaw Stand
Published
Introduction: Portable Metal Bandsaw Stand
About: I live in New England and currently have two degrees, one in Electronic Engineering and the other in Electrical Technology. I love building and tinkering whether its with wood, metal or electronics its all g...
This Instrucatable will show the constructed portable metal bandsaw stand including the tools and parts used.
Step 1: The Tools and Matierals
Tools
Portable bandsaw - Milwaukee metal bandsaw
Grinder
File
Table Saw
Drill
screw Driver
Wrench
Matierals
1 - 8' piece of half(shallow) strut
8 - strut 90's
19 - 1/4" or 3/8" bolts, washers, lock washers
1 - 3/8" x 6" mounting bolt with washer and nut
1 - 14" x 7" piece of wood or plastic
2 - sheetrock screws with washers and lock washers
1- Clamp
Step 2: Building the Stand
Cut the strut using the measurements shown in the picture.
You should end up with the following cuts:
2 - 24" pieces
2 - 16" pieces
2 - 10" pieces
2 - 8" pieces
Step 3: Assembly of Parts
once all the strut has been cut bolt all the pieces using the 3/8" or 1/4" hardware. After the stand has been constructed, cut the table/cutting platform using a Table saw if the piece of wood/plastic is not 14" x 7" already. Using the bandsaw or similar saw with the same blade thickness, cut a slit in the table to allow the blade to slide into it. Once cut, mount the table to the struct 90's using sheetrock screw and with washers. I would recommend pre-drilling the wood/plastic before screwing the table in. If the sheetrock screws stick out the top of the table, be sure to grind/file the sharp tip off.
Step 4: Tighting the Saw
Everything should now be in place with everything tight besides the 3/8" mounting bolt. Make sure the table and the was blade are perpendicular with each other and then tighten the mounting bolt.
Step 5: Using Your New Bandsaw Stand
If your bandsaw doesn't have trigger lock, use a clamp to hold the trigger down. You can also wire a switched outlet and plug the saw into that.
Step 6: Your Finshed!
Enjoy your highly versatile saw! you can make cool projects such as the ones shown above. To check out how I made the gut hook hunting knife click HERE or the aXe knife HERE
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    7 Comments
    is so nice
    Awesome idea. I was looking for a way to do this
    14, 3:09 PM.jpg
    heh a Porta-Band. I don't have one of those. I do have a 4x6 horizontal/vertical bandsaw though. It kind of does a bit of the same thing without the hassle of holding it up. I suppose a 4x6 takes up more space too.
    Here are pictures of a couple projects I have done recently mainly using my band saw.
    I made the tool rest on the left
    http://i.imgur.com/TlR7W9S.jpg
    I made everything but the motor, and the mandrel for this
    http://i.imgur.com/apyxXpJ.jpg
    I plan on making some other attachments to go with that second grinder, to slide on that tube. Being able to efficiently cut steel is key for working on metal projects. I think folks with those Porta Bands should have gotten 4x6 saws. No way you want to cut through some of that thick stock with a Porta Band.
    P.S. that 4x6 limit is just a suggestion
    http://i.imgur.com/YvLQO.jpg
    http://i.imgur.com/QsCXj.jpg
    Wow excellent post Ryan...! I might make one myself very cool....!!!!!!!
    Nicely done. That's one sweet way to get a metal bandsaw working the way you want it! Nice pieces at the end, there, too.
