Portable Mini Electronic Screw Driver Out of Scrap
Published
Introduction: Portable Mini Electronic Screw Driver Out of Scrap
Hello guys this is my 1st instructable sry for my english
This mini portable electronic hand screwdriver is made out of a deo can, it rotates in both clock and anti clock wise to fix and to remove the screws
hope u guys will like it :)
Step 1: Material Required
THINGS REQUIRED
1.An old deo can
2.A high torque geared motor of 100 rpm ( i have 100 rpm so i am using it it is not mandatory )
3.A DPDT switch
4. male and female Adaptor pins
5.L clamp for mounting the motor as shown in the above pic
6. a old screw driver
some wires
some screws
Step 2: Preparing the Deo Can
First make sure that the motor can be easily fixed into the can. and cut the can at the top and grind the edges wit the help of sand paper or with grinding tool no make a cut so that the dpdt switch can fit into it and a hole so the female adaptor can me fixed as shown in the pic
Step 3: Welding the Old Screw Driver to the Motor Shaft
cut the matalic part of an old screw driver and gas weld it to the shaft of the motor
make sure that the central axis of the motor shaft and the bit holder are same
Step 4: Soldering the DPDT Switch
as shown in the pic solder the wires
the middle wires (Red and black ) are given to the motor and other two wires are given ti the female adaptor pin
Step 5: Assemble
now asssemble all the parts at their provided sapce's
Finally your electronic screw driver is ready
hope u enjoyed it :)
    • Planter Challenge
      Planter Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    6 Comments
    but is it sonic
    naa just a joke
    nice work dude
