A miniature Lyre was constructed for a contest and it had to be carried to various schools. It was then obvious it needed protection
The lyre is similar to an earlier lyre type that was demonstrated in Instructable of Aug 5, 2009.
After assembly it was discovered that it was easy to play as a zither type instrument while mounted inside the carrier.
The construction is straight forward and if one uses a purchased box they can make this in 40 hours.
Remove these ads by
Signing UpStep 1: Construction [general]
Make the lyre first of all and follow the key instructions outlined in the above Instructable for the zither as far as making the tuner screws, the 13 notes from B to G above high C., and he layout here.
Tools- Pliers. ,Hemostat pliers,awl. drill bits .093 and .105 dia. Dremel tool {R} or a drill press could be used, hand saw ,
See first picture of the over-all construction.
Visit Our Store »
Go Pro Today »
If you broke it down to all the steps... it's a bit more work for you... but people trying to duplicate your efforts would have the additional steps you used instead of having to try to see them in a photograph.
My suggestion is to scan the documents you have above and include them as a PDF file so others can print them and follow along.
Thanks,
Jerry
I think it would help others be able to duplicate your project. (thumbs up)
Jerry
Good luck!
Jerry
Note that new information was added. See above Step 5. Some may want to add Sharps notes with keys. I have added the steps to include the sharps keys.
However, I also have trouble figuring out mechanical pencils, automatic litter boxes, and parmesan cheese containers with twisty tops.
are you sure that isn't a 90 degree angle? or a 135?
Roman Officer- "Small liar, small liar!"
Small Liar- "I didn't do it! I didn't do it! I wasn't even there! I was at a friend's house. The Check is in the mail!"
From my experience with earphones as mic, you can use it as stereo mic, pugging it into the mic hole of the PC. That adds a nice effect if you put an earphone to the rigth side and the other to the left.
I had to use a stereo pre-amplifier though..
