Introduction: Portable Music Player
Picture of Portable Music Player
Portable music player
simple and superb.
Step 1: Needed Components
Picture of Needed Components
ELECTRONICS LIST:
speakers 4 inch 3 watt
batteries 4v 1ah -2 or 4
capacitors , ic, resistors are specified in circuit.
mp3 module
plastic box
jumper wire
switches
TOOLS LIST
soldering iron and lead
wire splitter
cutter
etc.,
other: Sun board
Step 2: Circuit Work
Picture of Circuit Work
do all the circuits according to the schematic.
Step 3: Silver Jumper Wire to Every Component
Picture of Silver Jumper Wire to Every Component
solder the jumper wire to all the components so that they can be easily joined to the circuit.
solder the 5v input of the mp3 module to the output of the regulator circuit.
and audio output of the mp3 module to the jumper wire and connect thou the the amplifier circuit.
Step 4: Sun Board Cutting
Picture of Sun Board Cutting
cut the board as shown in the picture.
also cut for the speaker .
when I took this photo the speaker was already fixed.
after cutting fix them in place hot glue and screw them.
then attach the Sun board to the lid of the plastic box.
Step 5: Connecting
Picture of Connecting
connect all the components according to the circuit and close the box.
Step 6: Charging
Picture of Charging
if you use the 9volts 500ma-1 amp adapter no need to change anything.
but if you want to use 12 volts adapter, you have to add the above circuit.
Step 7: Play and Enjoy!! the Music Anywhere Anytime.
Picture of Play and Enjoy!! the Music Anywhere Anytime.
now our music player is ready to rock.
About This Instructable
248views
7favorites
License:
Bio: Electronics hobbyist
More by Manoj BR:DIY Wireless ChargerCardboard+ Lightings = Magic. Arduino Air Monitor Shield. Live in a Safe Environment.
Add instructable to:
