3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable PVC Conduit Antenna Mast
Step 3Insert Eye Bolts for Guying
Measure up about 18 inches from the flared end of one section and drill 3 holes through the center of this section. Space the holes about an inch apart and rotate the conduit with each hole so the eye bolts will be approximately 120 degrees apart (measure the circumference and divide by 3). Insert the eye bolts and tighten the nuts.
I plan to run coax up through the center of the conduit so I also cut a slot in the bottom of the base section where the coax will exit.
This would also be a good time to number each section. The top 3 sections each have one flared end. The top section being number 1. The second section , with the eye bolts, number 2. The third section with a flared end, number 3. The bottom section with no flared end, number 4.
1 comment
Dec 13, 2007. 11:20 PMWyle_E says:
If you're using four five-foot sections, you only need two ten-foot sections plus a coupling to add a socket to one of the five-footers. Of course, PVC tubing is so handy that that you'll probably find a use for that last five feet. You could, for instance, split a short length lengthwise to reinforce the section that you drill for the eyebolts.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:imarunner2
The picture is from the starting line at Grandma's Marathon in Duluth, MN. I'm in there somewhere near the middle of the pack.
