3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable PVC Conduit Antenna Mast
Step 6Screw in the Anchors
The anchors should be approximately 120 degrees apart and about 15 feet from the base. Start from the base and walk off the distance to each anchor location and screw it into the ground. Tie a tautline hitch with the loose end of each rope to each of the anchors. The tautline hitch is a knot that will allow you to make adjustments in each guy rope to hold the mast perfectly vertical.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
34
Author:imarunner2
The picture is from the starting line at Grandma's Marathon in Duluth, MN. I'm in there somewhere near the middle of the pack.
