Portable, Paperless, Digital Copy Machine
Step 5Final assembly
Final assembly
Remove the camera from the camera mount, if it is still mounted.
Insert the tops of the four rods into the bracket holes of the camera mount.
Secure the tops with the wing nuts.
   (Determine the best position for the nuts below the wingnuts, and
   lock them together.)
Insert the bottoms of the four rods into the Plexiglass plate.
Secure them with the stop nuts (hand-tighten).
   (Determine the best position for the nuts above the plate, and
Mount the camera and check the alignment.
   (Adjust the top, locked nuts as needed.)
2 comments
Oct 15, 2009. 12:56 PMsolsed says:
 and it may be possible (it used to be possible) to get lowreflectivity plastic or glass from picture framers and glass or plasticsuppliers. it is a bit more expensive but if you want quality results
Oct 15, 2009. 12:54 PMsolsed says:
 I suggest you make a sheer white fabric (eg ripstop nylon) hood togo over the legs. it will dramatically reduce reflections from aroundthe room and give more even lighting over the thing you are copying.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:DHagen
