3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable Propeller Engine
  • last photo ←
Have you ever had a rubber band powered balsa wood aircraft? I did, and i was mad when it broke. So i came up the the Portable Propeller Engine, I call it the Porta-Prop.
It is a self supporting rubber band powered engine shaft and blade. It is designed to fit a specific type of balsawood aircraft sold at Michael's craft store, but im sure it will fit any old thing you strap it to. Now you can play with the r-band powered craft as much as you want, and when it breaks, you can simply switch the prop over to a new plane! Here's how to make it....
Materials:
1 proconstructed balsa wood airplane (I got mine from MIchael's crafts for $1)
1 long and one small rubberband
1 or 2 Lego propellers (the bigger the better)
a small paperclip
less than a foot of 1/4" dowel rod (use poplar or pine)
certain common Legos, pictured below
Tools:
a ruler
a dremel tool or something with simiar drilling and sanding capabilities
superglue
needlenose pliers
silicone spray makes it much faster
remove the nose weight
Step 1Making the rotary shaft
  • last photo ←
It is pretty hard to give a good verbal description of what a lego looks like, so there are ample picture given.
1. get out your long rubberband and the three other legos pictured. A black ridged rod about an inch long, a gray friction nut, and a cylindrical hollow uni-bumb.
2. cut your rubberband and slide the ends through the top of the black uni-bumb.
3. slide the black uni-bump with the band in it onto the black ridged rod in such a way that the rubberband is also attached to the rod. Slide the gray friction nut onto the shaft, and put superglue between the nut and black uni-bump to help permanently attach these items to the black ridged rod.
4. (note in the photo i used a cylindrical unibump for this part, you should use two cubic unibumps)
get two cubic uni-bumps. you can lego lock them and glue them together to that the holes are facing the same direction.
5. Now get your propellors ready, and assemble the whole thing as shown in the first photo.
23 comments
Oct 5, 2010. 8:13 AMlukeD says:
i'v got a tip:
make better (cleaner) pictures.
but i like the instuctable!!!
Jan 25, 2010. 3:15 AMhassaan. says:
MechEngineerMike,
                          Hi,man i need serious help frm u, i have been given a project on making a glider plane which are not operated by any set of batteries or fuel allowed to use small pastic propellers on their planes.And i couldn't get to know frm ur presentation how to build a propeller?? ... plz help
Nov 21, 2009. 4:53 AMColonel88 says:
Good job, but sheet pics... Hard to understand, no offense
Sep 18, 2009. 5:49 PMplatinum97 says:
Do I have to use a propeller, can't I make one out of cardboard or sumthin, cuz I don't have time to buy one. Cuz with my friends we all make one of these instructables people make, then have fun with the things we make. So is there I way I can make a simple propeller out of household items
Sep 19, 2009. 6:18 PMplatinum97 says:
Thank you!! I wanted to make one actually! Thanks for the advice, I'm off to make the plane!
Sep 8, 2009. 9:54 AMktalex says:
hahah lol i saw this on the berenstein bears.
Aug 17, 2009. 11:21 PMSeanOTheDed says:
I know it is good to encourage people, but there are some glaring issues here with me. So, please take this as some constructive criticism please. The pictures are easy to fix really. Most camera buttons on the digital cameras are actually 2 buttons in one. Most will focus and lock on half a push, then snap the photo on the full push. Take advantage of this by holding your hand flat at about the distance the object is away. Half press and hold the shutter button to focus on your hand, then swap your hand with the object and snap the photo. Also most cameras have a "close up" mode. Look for a flower symbol or something. My main issue is this setup will not fly any different than if you glued a weight to the nose. If you use Legos it will be too heavy and accelerate rapidly into the dirt. Lego props are heavy, not cheap, and they are designed for play, not practicality. I just don't want to see a kid glue all his precious legos together, just for it not to work. Make sure to use the propeller the plane came with or another hobby/light weight one. You might need to modify it though. I love legos and I've been building things that fly for over 2 decades. So that little issue hit a soft spot with me. ; ) Other than that, the format was pretty rock star : ) . Keep up the good work and we look forward to seeing more!
May 3, 2009. 6:18 AMsharlston says:
i do this with moddle cars aswell
Apr 26, 2009. 9:09 PMj79jon says:
From a private real plane flyer...good to go.
Apr 25, 2009. 7:44 AMiectyx3c says:
LOL !!! I was a terrible 'ible photographer. Blurry, badly framed, you name it. Finally I started propping my cheapo camera on a bag of beans and some books. And using the self-timer - that is key I think. Anyway I can see your pictures just fine and the explanations are clear.
Apr 21, 2009. 10:27 PMtimjelly says:
lol...no offense
Apr 25, 2009. 7:36 AMiectyx3c says:
You've got my vote. Nice job and good explanations.
Apr 14, 2009. 9:35 AMdunnos says:
darn, I just came up with this but you already did it. only i was going to add the whole "build a plane from scratch" business
Apr 9, 2009. 10:07 AMdallyspot says:
Great instructable! But dude, get a better camera
Mar 30, 2009. 5:44 AMrimar2000 says:
Very good idea.
Mar 31, 2009. 11:04 PMMLROD says:
Does it work?
Apr 1, 2009. 4:07 AMrimar2000 says:
I suppose yes, I don't see any reason to not work.
Mar 31, 2009. 8:33 AMclemsonguy1125 says:
weel by the time you buy all the parts you could buy 4 or five airplanes
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:MechEngineerMike
as my name suggests, i am a mechanical engineering student. I LOVE math and designing and building my own stuff. There is always a better way to do something. I believe the power of human ingineuity c...
more »
