Here are the materials needed:
-Ruler (to cut straight lines)
-Sharp knife and scissors (to cut binder cardboard)
-Wire Cutters (what I use to strip wires)
-Screwdriver with small head (to take apart Monitor)
-3.5 inch TFT LCD Monitor
-2 Binocular lens with rings (the big lens)
-One black binder
-One 9vDC Plug
-One 9vDC Heavy Duty Battery Clip
-One standard 9v battery
Remove these ads by
Signing UpStep 1: Assembling the cardboard template
You also have to glue each lens to their rings (with the curved part facing up), and then proceed to gluing them together, with one on top of the other. Please note that the cardboard box is not the actual housing and will only be used to mark the size and shape of your flexible housing. Next proceed to gluing the lens into a hole that you must cut out from the box. Make sure the hole is centered or your imaged will not be perfect.
Visit Our Store »
Go Pro Today »
http://www.ebay.com/itm/TaoTronics-3-5-inch-TFT-LCD-Car-Video-Monitor-for-VCR-DVD-GPS-Rear-View-Camera-/170893566596?pt=US_Rear_View_Monitors_Cams_Kits&hash=item27ca0ce284
