3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable Skype Phone v2
Heres an easy way to make your own cordless phone skype ready, Dont need to open your phone, and you can dial from it as well! All for about $5.
Props to Vitali Virulaine at http://www.vital.pri.ee/PSTN/ for coming up with, and sam for inspiring me to show him up, I hope you get into the maxim party!!!
Step 1Parts needed
Parts needed
-2 mini audio plugs 1/8" (buy cheap headphones and cut off the plugs)
-an RJ11 Plug (buy a cheap phone cord and cut off one end)
-2 100OHM resistors
-500OHM variable resistor
-2 3.3uF capacitors
-9V adapter, or USB plug, or use the one currently in your phone.
41 comments
1-40 of 41next »
Dec 21, 2009. 11:05 PMgomalopa says:
There is some software like chat cord dialer for MAC or linux, im using Xlite under those systems.
Thanks
Feb 9, 2009. 9:01 PMHextor says:
I tried the new schematic and it didn't work, I didn't use a pot though so perhaps that why. I agree that it's not to specific about how to connect it.
Jan 24, 2008. 2:49 PMnaoakes416 says:
I looked up that schematic on google and it said that this particular setup had echo problems... have you experienced that at all? also it shows a slightly different newerversion but it doesnt explain it very well... and i was just wondering what to do. Thank you.
Jun 6, 2007. 10:50 PMratgod says:
If you get an incomming voice chat request, does it allow you to accept it with a button press?
Dec 2, 2007. 1:19 PMgrahamslawson says:
nope. Its not connected like that
Sep 22, 2006. 12:40 PMSqueeto says:
Thanks for the info. I could sure use one of these and I know I have all the parts. Unfortunately the software doesn't run on Windows 2000. I have read that the earlier beta versions to 1.3 do work for 2000. Any chance you know where I can get it? Chat-Cord@DialerSK 2.1.0 Setup "Chat-Cord@DialerSK runs only on Windows XP or Windows ME"
Aug 8, 2006. 10:22 AMsagefool1975 says:
Hmm, so I have made the original and modified circuit and they both seem to work fine, my problem is that the input volume doesn't match the output volume. So if I call the skype test center, leave my message and hear it played back to me, it is incredibly faint. I've tried playing with the gain levels on my input but even maxed out it doesn't get a great signal. Any thoughts?
Jul 24, 2006. 6:06 PMTABRadi0 says:
I know that, But I'm really setting this up for my grandparents, that aren't computer literate. I personally built one of these last week with no problems, It works great for me but it will be alot of hassle for them.
Aug 1, 2006. 7:17 PMsirstargazer says:
do you have the echo problem? I've tried both the old and new version of this and I still get a bad echo
Aug 1, 2006. 3:14 PMtommiedeboy says:
hey there TABRadiO, i'm dealing with the same problem and i'd like to get this solved. there must be something. i had another program but don't seems to work with my phone. here's the link:http://phoneconverter.com/en/Downloadskype12/setupskype12.exe
please leave me a note if you've found something
Jul 24, 2006. 12:43 PMTABRadi0 says:
The Chat chord software is expired. Is there any other offered software that will work with this particular hardware?
Jul 24, 2006. 2:00 PMsirstargazer says:
you don't need the software for this to work. the software just lets you dail using the phone's numpad. that's it. you can still use your phoen to talk without the chat cord software.
Jul 1, 2006. 2:55 PMconalcharles says:
Where do the guys in the US get electronic components from ? Does RadioShack have it off the rack or do you use some online sites ?
Jul 2, 2006. 11:48 AMsirstargazer says:
radioshack didn't have the capacitors here so I had to get it from another electronics shop. look in the phone book, i'm sure there are many small electronic shops out there.
Jun 28, 2006. 3:39 PMtyeo098 says:
ohh... nvm i get it
Jun 28, 2006. 3:20 PMtyeo098 says:
Uhh... Stupit Qwestion here how do u hook it up to the phone and stuff? just email me at tyeo098@yahoo.com (too lazi to chek back)
Jun 21, 2006. 8:48 AMadoqpweoriuqwer says:
I'm confused about the phone jack part of the circuit. Which of the pins do I want to connect and what do I want to connect them to? Maybe a picture would help to show the direction the jack is facing? Thanks
Jun 18, 2006. 2:10 PMsharath says:
I faced the following problem. I think the circuit is fine. During the installation of the plugin, under phone keys tuning, there was no response even though i pressed the keys. Further if i press the numeric keys on the computer keyboard, the installer recognizes them. Also, the phone display, constantly shows "Line in use", when i connect the ckt. What may be the problem ?
Jun 20, 2006. 1:40 AMsirstargazer says:
did you make sure that the circuit really is working? when you use the phone, can you hear music you're playing in winamp or something?
Jun 20, 2006. 8:32 PMsharath says:
When i make a call in skype ,by pressing the keys on computer keyboard, i can hear the ringing sound. When the other person recives the call, i cant hear anything. not even noise.
Jun 20, 2006. 8:30 PMsirstargazer says:
has anyone tried the new circuit? i'm trying it out but can't seem to get it to work.
Jun 12, 2006. 4:45 PMmacfreak4 says:
you haven't done anything wrong, according to the author's site. there's a modified circuit that was posted on the original author's site on june 16 -- the mic in audio jack is now connected before the 500 ohm pot instead of after. this is supposedly to eliminate echo, though I have not yet tried it (i built the original circuit listed here)
Jun 16, 2006. 3:32 AMsirstargazer says:
sorry hehe i'm blind or something and can't find the modified circuit you speak of. do you think you could post the link to that modified circuit? :)
the one on http://www.vital.pri.ee/PSTN/ is the same one used here
Jun 16, 2006. 3:37 AMsirstargazer says:
haha oh wait, scratch that, it IS at http://www.vital.pri.ee/PSTN/ I just didn't notice the line that says "or MODIFIED version (12 june 2006) (should resolve echo problem)" part way down from the top.
Jun 12, 2006. 4:49 PMmacfreak4 says:
although, I had to use a 600 ohm resistor instead of the pot to get decent volume output from my wired phone -- go figure :P
May 30, 2006. 7:04 PMsirstargazer says:
I was under the impression that left and right were tied together and the 2 ground wires from each earpiece is tied together, thus giving you two ends. that's the way I have it built right now. I couldn't find a variable resister so I just use a 10ohm one instead. I was using a 470 one but I could only hear, not speak into the phone. I accedentally switched in a 10 and now I can both hear and speak but the person that i'm talking to on the other end will hear an echo of their voice and they can also somehow hear the speaker out signal comming out of my computer. anyone know what i might have done wrong? I'm going to try and increase the 10 to something closer to 470. maybe 400 or something.
May 30, 2006. 10:24 AMsagefool1975 says:
So with the mini stero audio plugs, should I just tie the left and the right channel together? As it is I am using left for - and right for + which gives me the fun of being able to adjust the volume by sliding the balance control away from center on my computer - but probably isn't so hot on the components.
May 29, 2006. 10:52 PMtenemag says:
I'm in the process of building one right now... actually, I'm wondering... What is the purpose of having the pot resistor on there? volume control? also, when I cut the phono wire I had, it had 3 wires inside, a white wire, a red wire, and a silver uncoated wire... which wires do I hook up for mic/spk? thanks!
May 23, 2006. 7:19 AMIrregular Shed says:
@ Hungry_Myst:
Looking at the way that the circuit uses the two USB ports, it's so as to get a total of 10V instead of 5V for the circuit (which, with the battery, is 9V). I think you could use a single USB port for power if you were willing to build a circuit to up the 5V to 9V... but you might end up going over the 100mA limit that a USB port will give to a device. It's a bit of an ugly hack either way - I'd pull 12V from a spare Molex connector and fiddle with the pot to control the gain.
Last night, when I saw this, I thought of a really neat way to use this circuit - marry it up to one of these cheap USB audio adaptors...
http://tinyurl.com/mh762
...and hook it up to an internal USB header - taking the power from a spare Molex connector, as mentioned above - and wire up a standard phone jack to a blanking plate - maybe even one stolen from an old modem =)
That would be fab stuff.
May 23, 2006. 3:09 AMpurrv23 says:
Awesome Instructable!!! I went out and got the parts and built it today... my first PC board project box! it works like a charm.... I could only find 4.7uF capacitors, but they seemed to work... the person at the other end of the call (on a land line) tends to hear some echo and slight feedback, not horrible, but a bit annoying... is this due to the change in capacitors, or maybe just my computer and wireless setup? any idea's on refining this would be awesome.... 3 cheers for VoIP!!!
May 22, 2006. 9:08 PMandreq says:
Are the 3.3uF capacitor really necessary ? Ive built one with 10uF and I get a lot of trouble... for exemple : My friend can hear the sound that the computer is actualy playing (even with Mic input selected...) .. Ill try to find 3.3uF and see if it help...I'll aslo try a 470ohm resistor instead of a pot (of 4kohm...)
May 22, 2006. 7:15 PMwifigod says:
Where is the best place to get the capacitors from? I tried Radio Shack and Digikey w/o much luck. I've been wanting to do a project like this for some time now, I'm excited somebody has posted instructions on Instructables. :-)
May 21, 2006. 6:07 PMHungry_Myst says:
Any tips for using power from the phone? I haven't looked into it mind you, but would it be any more difficult then adding a resistor? Or could I use USB without takeing up 2 USB ports as was shown on the original website?
May 21, 2006. 5:49 PMmikesty says:
Alright. IIRC the grynx chat cord writeup dealt with euro phones, so I wasn't sure if perhaps you were a euro. I did know that Canada pretty much has the same telecom system as the U.S. - guess I should be more investigative next time :) Thanks! On another note, I think I am actually going to built two of these. One will be a cordless phone for skype as I have planned, but today I also found a broken old cordless phone with what I believe is a fully functional base station - I figure I can use the speakerphone on it while I'm at my desk to make skype phone calls :) If not that I can just use it to chat on vent while I'm in the room :P
May 21, 2006. 9:43 AMsagefool1975 says:
Is there some source to the Chat-Cord for use non windows users?
May 20, 2006. 1:39 PMsam says:
i think i just got hustled... i was writing up the same thing...
May 20, 2006. 1:38 PMmikesty says:
Oh, hm, does this work with phones in America too though?
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:matt
I liked designing and building things long before I became an engineer, now I get paid to do it!
