Portable Solar Generator
2,533
70
9
Posted
Introduction: Portable Solar Generator
The following are instruction on how to build the portable solar generator.
Step 1: Step 1: Get Your Supplies
In order for this project to be completed, a number of items will be required: A large plastic case (big enough to fit all the supplies), a 200-400 watt inverter, 18 amp battery, charge control, volt meter, pliers, wire cutters, wire crimpers, wire, fuse connectors, electrical tape/zip ties, and a drill.
Step 2: Step 2: Get Your Inverter
To make this project work properly, a 300WT to 400WT inverter is needed. This is a 350WT inverter.
Step 3: Step 3: Battery
The best kind of battery for this project is an 18 amp battery.
Step 4: Step 4: Charge Control
A charge control is needed to make sure the battery does not get over charged. This charge control comes with a volt meter, they can be gotten separately but this one is a combination of the two things.
Step 5: Step 5: Velcro
Apply industrial grade Velcro to the battery, volt meter, inverter, and solar panel.
Step 6: Step 6: Setup for Inside the Case
The Velcro will stick into the case. This is the setup we used for our handgun case. A different case might need a different set up.
Step 7: Step 7: Begin Wiring the Charge Control to the Solar Panel
This is the wire from the charge control that will be connected to the solar panel.
Step 8: Step 8: Drill Case
Drill a hole in the back of the case so the charge control wire can connect to the solar panel.
Step 9: Step 9: Connecting the Charge Control to the Solar Panel
This is where the wires connect to the solar panel. Make sure to keep the wires close together so they don’t pull apart.
Step 10: Step 10: After Connection to the Solar Panel
After the solar panel is wired, connect it to the top of the case. This is what it should look like after it has been put on with Velcro.
Step 11: Step 11: Bolt Charge Control to the Battery and Clamp the Inverter
Once that is done, bolt the charge control to the battery, then use the clamps from the inverter to connect to the battery. The clamps can be removed and bolts put on the battery, but I feel it is safer to use clamps in case of an emergency.
Step 12: Step 12: Finished Project
This is the finished project, switch on the inverter, the volt meter should be measuring roughly 12 volts, if not put it under the sun to charge. Be sure to monitor it to make sure it is charging.
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
9 Comments
That's really good innovation, battery get charged any where if there is power is available or not. By using portable generators this made very easy.
Aidan is the best
Hey World you should vote for Aidan he is a great man, he is the best man around town. Let me tell you a lil something about Aidan, he has been through a lot... you might not know this but he has scoliosis and a dislocated rib and hip. He loved sports but now he cant play anymore because his injuries... This project means alot to him... thankyou everyone for voting
I like it, good job.
Would you be better to add a 12v car adaptor to charge things like mobile/tablet/etc by way of USB?
I was thinking about wiring in a dual USB charger, but never put it in. The inverter does have one USB port in it, but in the furture I will probably install it. A car charger is a good idea, I didn't even think of that, thank you.
nice idea, one question though, how do you make sure the battery doesn't die? the inverter wil just keep pulling energy from the battery and as with all lead-acid battery's, it will die when down to a certain voltage. might be a good idea to add something to limit this. IF it isn't included inside you inverter already. (which it sometimes is)
There is a charge control with the volt meter that limits the amount of energy. Once the battery has reached its capacity it will stop charging. I also keep the inverter off unless I am using it. It has a switch and clamps that connect to the battery that I don't use unless in use.
Great job on your first Instructable! I hope we see more from you in the future!
