Introduction: Genius Portable Solar Water Heater Energy Module!
New : Low Cost - Genius Foldable Portable Solar Swimming Pool Heater - 2 K Watt - Do It Yourself Heating Device - Reinvented And Created For You
Step 1: New : Low Cost - Genius Foldable Portable Solar Swimming Pool Heater - 2 K Watt - Do It Yourself Heating Device - Reinvented and Created for You
Solar Swimming Pool Water Heater - 2 k Watt
www.warm-water.be Reinvented and Created for You !
- Off - Grid power ! Safe - 12 Volt !
- Easy ! To understand !
- Fun !
- Easy to assemble ! Fast setup !
- Independent ! no need of a filterpump ! Go to the Youtube : https://www.youtube.com/watch?v=fkmiSuzY1dk
- Portable, Foldable, Small, Easy to transport in a Ryanair - proofed suitcase
- No electric wire ! Eco - friendly ! Fun ! Warm ! High Tech ! No screwdriver ! As simple as an IKEA bookshelf !
What do you need ?
- a Solar fountainpump : Ubbink Solarmax 600:
- Solar panel 12 Volt and pump 12 Volt -
- Pump 610 l/h max , head 1,7 m max. Solar panel 10 Watt.
- ( or the Ubbink SolaMax 1000 )
- https://issuu.com/g2j.net/docs/solarmax_600_cert.
- https://issuu.com/g2j.net/docs/solarmax_1000_incl_battery
- 2 X Solar collectors : Intex Solar Heater Mat: https://www.promobutler.be/nl/zwembaden-sauna/zwembaden/solar-mat-3819974
- www.intexcorp.com/support/28685e.html
- - Dimensions mat: ± 1,2 m x 1,2 m. Surface: 2,017 m²
- ( or 50 m black garden tube 25 mm = 1,25 m² )
- or KESSER® ECO zwembadverwarming, 108 x 74 x 15 cm (l x b x h), warmwaterverwarming, zonneverwarming voor zwembaden, UV-bestendige kunststof
https://www.amazon.com.be/-/nl/zwembadverwarming-warmwaterverwarming-zonneverwarming-zwembaden-UV-bestendige/dp/B09TB3L178/ref=asc_df_B09TB3L178/?tag=begogshpadd0d-21&linkCode=df0&hvadid=633344606085&hvpos=&hvnetw=g&hvrand=12255314864398529213&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=1001021&hvtargid=pla-1639050089405&gclid=Cj0KCQiA1NebBhDDARIsAANiDD3nSfZGoxJ-XwtMVSyM46hlnSpmj1ABLOG5gdo_iAYsrcOcRUmtJL8aAsUgEALw_wcB&th=1
- 2 X blue tubes 32 mm x 200 cm
- PVC 4 X elbow white 32 mm 87°
- 2 X joint sleeve for PVC pipe 32 mm, 2 X Stop 32 mm
- a Adapter tube - reducer 32 mm / 13 mm ( see pictures and step 3 )
- That's All
- Go also to the website's:
https://solarpoolheatersite.wordpress.com/
Testresult in Step 9
Step 2: Order All the Parts : the Solar Pump and the Solar Heater Mat ( or Garden Hose )
When you like to build it, watch https://www.youtube.com/watch?v=fkmiSuzY1dk
The Portable Solar Pool Heater( Unit, Module, System, Project )
( order all the parts, but google first for the lowest price ! )
http://www.ubbinkdealer.nl/ubbink-solarmax-incl-solarpaneel-en-pomp ( Ubbink SolarMax 600 = Solar Pump 12 Volt and Solar PV panel12 Volt )
www.fun.be( blue tube 32 mm)
Brice plan it ( elbow and tube sleeve 32mm )
Step 3: Make Your Own Genius Portable Solar Heater Module
The power of raw sunshine at midday on a cloudless day is 1000W per square meter. That’s 1000 W per m2 of area oriented towards the sun.
Solar Bag 1-2-3 = 1,04 m² = 1,04 k Watt or
Two Intex Solar Heater Mat = 2 m2 = 2,017 kWatt or 2017 Watt or
50 meter black garden tube 25 mm = 1,25 m² = 1,25 k Watt
Step 4: How to Make the Reducer/adaptor - Tube:
To make the reducer/adaptor - tube:
Go to a DIY shop and buy small pieces of tube from different diameter from 13 mm up to 32 mm. Slide one into the other. Make sure they slide tight ! That's all.
Step 5: Manual's
Unpack Intex Solar Heater Mat, and read INTEX OWNER'S MANUAL. - SOLAR HEATER MAT
Unpacking Ubbink SolarMax 600, and read Operatng MANUAL SolarMax 600
Step 6: How to Connect 12 Volt Pump to 12 Volt Solar Photovoltaic Panel !
Before you connect the 12 Volt pump to 12 Volt Solar photovoltaic panel,
make sure the photovoltaic panel is covered.
When the photovoltaic panel is covered, no current will flow ! And the pump is standby.
Submerge the pump in the Pool.
Once the photovoltaic panel is exposed to the sun, the pump starts pumping.
Step 7: Connecting 32 Mm Blue Tube to Adaptor, Pump and Intex Solar Heater Mat
Connect 32 mm blue tube to pump and adaptor 32 mm / 13 mm and Intex Solar Heater Mat
See image, photo
Connect other 32 mm blue tube to output of INTEX Solar Heater Mat.
( black 32 mm tube in the photo )
See image, photo, picture.
Step 8: Swimming
My swim coach instructed me to swim every day on holiday.
I went on holiday to Cyprus and the water in the Pool of the Hotel was cold. That's when the idea started in my mind, to invent a portable heater ! To warm Pool water !
Step 9: WATER HEATING TIME CALCULATOR
Step 10: Testresult of Test in South of France 2016
Test with a Blue Ocean Solar bag 1-2-3, a Intel Solar Heater Mat, a esotec Solar Pumpensystem " Milano", and blue 32 mm tubes
( After the first day, a wire from the ceramic pump broke, that why I used the fountain pump )
I was lucky that I had my first fountain pump 0,6 m3/h max and my first Solar panel 12 Volt with me. ( Milano - esotec Solar Pumpensystem )
The mat and the bag heated the water 4°C, from 23,3°C to 27,3°C ( Ocean Blue Solar bag 1-2-3 and Solar Heater mat intex )
Next demonstration februari 2017, Tenerife Spain !
Step 11: Improvements : Insulation ! and Using the Green House Effect !
When you lay the collectors on the ground.
You might put some insulation first.
Covering the collector with a plastic or glass plate,
will improve the results.
Step 12: Conversions
Step 13: NEW ! SolarMax 1000 Ubbink
Discharge head: Max. 0.9 - 2.1 m
Circulation rate: 980 - 1350 L / h
Cable length: 5 m
Solar panel dimensions: 52 x 35.5 x 2.5 cm (H x W x T)
Solar panel with ground spikeIncluding lead battery storageBattery storage power: 12 V, 7 Ah
Battery storage dimensions: 151 x 65 x 97.5 mm (L x W x T)
Battery storage cable length: 5 mBrand: Ubbink
Summer Fun Contest 2016
Beyond the Comfort Zone Contest
Outside Contest 2016
