Step 4Balancing and mounting the solar panel:
A larger solar panel could be mounted on the rig, and solvent could be used to remove the grease from the ball bearings, and light machine oil added instead, to track at the same rate.
Two clock mechanisms, mounted in tandem, should work quite well for even larger solar panels -or a lightweight solar oven, mounted on a horizontal "lazy susan" ball bearing base. But, in the case of a solar oven, it seems that the best way, for a solar tracker, would have the cooking pot resting securely on a firm foundation, with a lightweight clock-driven reflector / glass window housing revolving around the heavy cooking pot. Only upper and lower reflectors would then be needed, to compensate for latitude and solar angle.
Let me know if you try this, as I have to move on to other projects and simply don't have time to develop and refine it. But I love to see how these things progress.
Add Comment
