Remove these ads by
Signing UpStep 1Supplies
You will require:
LM or MC 7805 +5VDC Voltage Regulator
Type-A Female USB Port
100 UF Electrolytic Capacitor 10-50v
0.1-0.5 UF Capacitor 6-50v (any type would do)
150-160 ohm Resistor (optional)
9V Battery clip
2.2V 20mA LED color of your choice (optional)
Unprinted circuit board
ON/OFF Switch (optional)
These parts can be easily purchased at your local electronic store, like Radio Shack. Or you can buy them online at:
http://www.digikey.com
Regulator:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=LM7805CT-ND
USB port:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=151-1080-ND
100 uF Capacitor:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P12392-ND
0.1 uF Capacitor:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=399-4151-ND
Alternatively do away with the whole thing, use a 4 x AA battery holder for alkaline cells = 6 volts, forward bios i silicone diode to reduce to approx 5.2 volts and a lot more current, a 9 volts only about 70mA .
Iam very much interested in making the charger but iam a totally novice when it comes to PCB and itching and cutting them nor I have any knowledge of caps or resistors... can any one load video of the entire process please >>>>
The PCB isn't really necessary because you can also use a breadboard or something. I use a perfboard and it works great.
Caps (capacitors) can store energy for a time, such as your computer does.
Resistors are like a dam, they stop the energy or convert it to heat.
I hope I could help you a little
i have seen also same schematic as yours.
http://www.simple-electronics.com/2011/08/usb-charger-circuit.html
that picture was supposed to have a 9 volt battery but I must have messed up somehow. oh well!
its really good for a quick charge, though, but be sure not to leave the battery in when you aren't using it.
yes! of course!
You can *NOT* use a 6 volt input for the 7805 5V regulator as that regulator needs to have atleast 7 volts to work well. I'm not sure what input you are planning to use, but depending on your space something like two 6v lantern batteries in series (have one of the batteries positive + terminal connected to the other batteries negative - and use the remaining for your power of 12 v ) or you could use 6-8 AA batteries for your power source for the regulator.
1.battery heats up
2.voltage regulator also heats up
3. it doesn't charge
the battery i used is Energizer max
PLS HELP ME :(
and the that i tried to charge DS lite and ipod nano 5th gen
oh and also im new on electronics and i dont know how to use a multimeter but i can read schematics because im a kid :P im 11
To be honest you don't even need the capacitors and resistors. Just wire it up the regulator like normal without the extra components and measure it to make sure it's producing 5V then the most important part
MAKE SURE YOU CONNECT BOTH data+ and data- TOGETHER
i have tried this with iphone 4 and it chargers.
i have another circuit that involves x2 2.5vdc solar cells connected in series and this also chargers the iphone.
I plan to modify this circuit to charge using solar cell and also use the solar cells to charge a 9v rechargeable batt. Of course this circuit comes with a cutt off feature to prevent over charge
thanks,
-R
