Remove these ads by
Signing UpStep 1Supplies
You will require:
LM or MC 7805 +5VDC Voltage Regulator
Type-A Female USB Port
100 UF Electrolytic Capacitor 10-50v
0.1-0.5 UF Capacitor 6-50v (any type would do)
150-160 ohm Resistor (optional)
9V Battery clip
2.2V 20mA LED color of your choice (optional)
Unprinted circuit board
ON/OFF Switch (optional)
These parts can be easily purchased at your local electronic store, like Radio Shack. Or you can buy them online at:
http://www.digikey.com
Regulator:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=LM7805CT-ND
USB port:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=151-1080-ND
100 uF Capacitor:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail?name=P12392-ND
0.1 uF Capacitor:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=399-4151-ND
thank you!
marC:)
thank you!
I do not know if this circuit is working.
Thank You.
Alternatively do away with the whole thing, use a 4 x AA battery holder for alkaline cells = 6 volts, forward bios i silicone diode to reduce to approx 5.2 volts and a lot more current, a 9 volts only about 70mA .
You can also use the LM317 to obtain a regulated output of 4.5v.
Iam very much interested in making the charger but iam a totally novice when it comes to PCB and itching and cutting them nor I have any knowledge of caps or resistors... can any one load video of the entire process please >>>>
The PCB isn't really necessary because you can also use a breadboard or something. I use a perfboard and it works great.
Caps (capacitors) can store energy for a time, such as your computer does.
Resistors are like a dam, they stop the energy or convert it to heat.
I hope I could help you a little
i have seen also same schematic as yours.
http://www.simple-electronics.com/2011/08/usb-charger-circuit.html
that picture was supposed to have a 9 volt battery but I must have messed up somehow. oh well!
its really good for a quick charge, though, but be sure not to leave the battery in when you aren't using it.
