3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable USB Charger (Version 2.0)
Step 3Attching the components
Watch the polarity when putting in the components, especially the regulator, or it will get very hot and burn out.
*BEFORE plugging in your USB device to this charger, test the charger's output using a multimeter. Hookup the 9-volt battery and measure voltage output, it should be between 4.8-volts to 5.2 volts.
*If the black light comes on when you plug the iPod into the charger, that means the charger is working correctly, and if the black light doesn't come on after 3 seconds, remove the iPod from the charger immediately, and recheck your charger for shorting or incorrect polarity.
*If you double checked the output and still no luck, try attaching a resistor bank described in the comments below to the data lines.
3 comments
Jan 24, 2011. 7:59 AMshanmugammpl says:
I suspect this pinout is wrong! because it caused my phone to reboot! and looking at this website
http://pinouts.ws/usb-pinout.html
clearly the polarity is swapped! and when i did try swapping them my phone didn't charge but didn't reboot either! so i guess i need to try the resistor to data line method!
Apr 23, 2011. 12:25 PMmarkcra says:
Agreed, I mistakenly used the above image as a reference and when testing my usb charger the polarity was wrong. I've reversed the wiring in line with pinouts.ws/usb-pinout.html.
Dec 17, 2009. 3:39 PMedwardapricopoai says:
did this it works just great
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:GoodAtIt
