3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Portable USB battery pack bike light (with a Luxeon III conversion)
You've probably seen how handy it can be to have a portable USB power supply for charging iPods, PSP, cellphones etc. I decided to make one but it needed to be multipurpose to justify carrying around the extra weight.
I wanted to make it as simple a possible so I decided to use 4 AA sized NiMH batteries rated at 1.2v (or 1.25v) Which can provide the needed 5v without regulation. This also makes it possible to more quickly charge PSP's which can draw almost 1A when charging.
To extend the functionality I decided it should also be a flashlight. But a quick search of the local stores showed that most AA flashlights are generally 1 or 3 cells. Fortunately for me I decided to check the bike aisle at Wal-Mart and found that many of the bicycle headlights are 4AA cell!
So using a bicycle headlight we'll end up having a:
1. portable USB power
2. flashlight
3. bicycle headlight
Not only that but I happened to have a Luxeon III star and optics laying around the house so, why not improve this project by switching out the bulb for the Luxeon?
Expandable Capacity Bicycle Headlight
The most interesting part for me is that if you decide to make a second battery pack and connect them together via USB you'll double the burn time of the flashlight! How cool is that when being used as a bicycle headlight?!?
How about connecting it to a USB power generator such as the Hand Crank Lego USB charger set up so it's turned by a tire?
Multipurpose enough? I think so.
Step 1Parts
Parts
You'll need:
-1 Bicycle headlight (4xAA type)
-4 rechargable NiMH AA batteries
-1 Luxeon III star
-1 Luxeon Optics
-1 Heatsink for Luxeon (I used a copper pipe cap)
-1 Resistor ( Luxeon resistor calculator )
-1 USB motherboard adapter
Where to find parts
I didn't have to buy a headlight but they can be had at the bicycle section of most stores.
NiMH batteries. Again I had these as well as a charger. I got them from Walmart. They are 2500mAH generic, $5 at in the electronics section. I think they had it also availible with a wall charger for a bit over $10. Either way they're half the price of the brand names.
I don't remember where I got the Luxeon III, somewhere online with the optics and resistor. I believe everything cost about $10 shipped. I would suggest using either 5 or 10 degree lens.
The USB motherboard adapter I got from ebay for $2 plus $2 shipping
19 comments
Jan 26, 2009. 11:25 PMjames.mcglashan says:
can this be easily be put in a box with a bike generator so I can plug in the usb port and charge my mp4 player and use speakers to amp the sound
Aug 17, 2007. 2:57 PMSadam and Osama says:
i have thought of making something similar to this, but i cant find the motherboard USB port. i've searched on ebay, found some, but i dont have a creditcard nor do i trust the sellers by mailing money TT__TT
Nov 18, 2008. 10:56 AMn0ukf says:
How are your desoldering skills? Get a cheap (or damaged) USB hub, or a non-functioning computer and scavenge the USB ports. Some of these will be a dual port, others (the thinner hubs) will be single. Look at whether they're stacked or not.
Jun 20, 2008. 4:21 PMduct_tape_masta says:
u lyk my mudkips??
Oct 10, 2008. 9:47 AMdanielemur says:
awesome instructable. but dosen't melting plastic release a dangerous gas?
Nov 8, 2008. 10:17 AMn0ukf says:
Don't breathe the fumes then. Your work area should have at least the capability of being well ventilated, whether you're burning plastic, soldering, etching, gluing, painting or whatever.
Nov 17, 2008. 5:58 PMdanielemur says:
oh. thank for the tip.
May 2, 2007. 12:12 PMnagutron says:
I love the idea of making portable power a liquid commodity that just follows me around, usable with any of my devices. My personal cloud of electricity. For a biker like me, the bike light is a perfect candidate - It's cheap and I already carry it around everywhere, so why not have it do some work when I get to where I'm going? Great photos and instructions, by the way.
Aug 23, 2008. 11:10 PMalex-sharetskiy says:
um, there;s already things like that..
Wireless power eh? link -> here
May 2, 2007. 8:32 AMTheOneGreatX says:
Cool! Can you use the light and the USB Port at the same time?
Aug 23, 2008. 11:05 PMalex-sharetskiy says:
put a dymo on the wheel, attach with hot glue, and instant power, you'll need to use a variable voltage regulator
May 15, 2008. 2:39 PMW8del4 says:
nice instructable!
May 21, 2007. 8:06 AMWildBlueRhino says:
This is cool. I'm thinking about making something similar myself. I'd use 4 AA batteries. Sometimes rechargeable, sometimes not. Would you advise using a voltage regulator? Would the volt reg provide a constant 5v even when the batteries are low? Been looking all over but can't find these answers
May 26, 2007. 6:20 PMWildBlueRhino says:
Thanks
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:warlord
