Portable Washer Pit Tailgate Game
Introduction: Portable Washer Pit Tailgate Game
Tailgate Challenge
First Prize in the
Tailgate Challenge
My friends and I are big-time tailgaters and we go to plenty of college football games in Texas. Every year we add more equipment and last year, we wanted some tailgate games. Unfortunately, we found most of the tailgate games at our local stores were plastic and didn't hold up to being packed up and stepped on throughout the football season. My Pops said it would be easy to make a long-lasting, portable washer pit on the cheap. I admit, he was right.
We made a few of these and thought I would share. Materials were about $30 and took about 6 hours to complete.
Step 1: Materials
  • (1) 1/2", 2'x4' plywood
  • (2) 2"x2"x 8' board
  • (2) 1/2"x2"x8' board
  • (8) 3" deck screws
  • (8) 1" screws
  • (20) 1" finishing nails
Other Stuff:
  • (1) bottle wood glue
  • (1) 2'x2'x1/4" carpet pad
  • (1) 2'4"x2'4" outdoor carpet / artificial grass
  • (2) cabinet door handles
  • Box Cutter
  • Hammer
  • Jig Saw
  • Hack Saw
  • Tape Measure
  • Power Drill w/Screwdriver Bits (or a regular screwdriver and ton of elbow grease)
  • Sandpaper Sheet
  • Pencil
Step 2: Cut Some Stuff
2' x 4' Plywood:
  • Cut in half for (2) 2' x 2' boards
  • This will be the main surface
2" x 2" x 8' Board Support Frame:
  • Cut (2) 21" long
  • Cut (2) 24" long
  • These will be used to make the support frame under the surface boards
1" x 2" x 8' Trim Board:
  • 2 boards 24' long
  • 2 boards 25 3/8 long
  • These will be the finishing trim on the outer edges of the surface
Carpet Pad:
  • Cut (2) 2' x 2' squares
  • Goes under the carpet to dampen the bounce when you throw the washers
Artificial Grass / Carpet:
  • Cut (2) 2' 2" x 2' 2" squares
  • This is the top surface
Step 3: Cut Surface Holes
Take one 2'x2' plywood board and find/mark the center. Use the 3" PVC pipe to draw a circle around the center mark. Cut or drill the 3" hole in the middle of the board. Jig saw works best.
Repeat on second board.
Step 4: Build Frame
Let's build out the frame. First, line up the frame boards flush with the 2'x2' surface boards. Screw in a 3" screw into the ends of the frame boards (one in each corner). This will secure the frame together and it's ready to be attached to the surface.
Repeat for second frame.
Step 5: Attach Frame to Surface
Now it's time to attach the support frame to the 2' x 2' surface/plywood boards. Use wood glue on the bottom edge of the 2' x 2' support frame and attach to the surface/plywood. Make sure the frame is flush with the surface board then nail four 1" finishing nails to secure the plywood to the frame.
Repeat for second surface/frame.
Step 6: Cut Carpet Pad & Attach
Find the center of the carpet pad, mark it, and use the 3" pipe to draw a circle and cut it out.
Use plenty of wood glue to attach the carpet pad to the plywood surface. Add some weight and give it a few minutes to attach properly.
Repeat for second board.
Step 7: Cut & Attach Carpet
Take the artificial grass/carpet, find and mark the center, and with a knife or box cutter. Cut your circle like cutting pizza slices. Do not cut in a circular fashion.
Cut 2"x2" squares out of the corner of the artificial grass/carpet. Apply glue to the bottom of the carpet and attach to the surface. The edges should drape over the plywood surface but go ahead and fold the flaps down to secure to the side of the plywood and support frame.
Step 8: Add Trim
Use glue to attach the trim to the side of the surface boards, then attach with 1" screws to the frame itself. Make sure it's flush with the top so that the support frames are the only thing that touch the floor.
Step 9: Add PVC Pipe / Cup
Push the 3" pipe through the hole until it stops on the floor. Mark the pipe just below the carpet line.
Now, remove the pipe and cut it (with a hack saw) at the mark you made. The edges of the pipe may be a little rough so smooth pipe edges with sandpaper as needed.
Apply a little glue to the top side of the "pizza slices" and slide the pipe through the hole.
Step 10: Attach Handle
Attach your cabinet/door handle to the edge of one side of your board.
Pat yourself on the back. Repeat. ALL DONE!
Finally, buy a washer set (8 washers total, 4 for each side) – there's lots of team branded ones but you can get real metal washers from your local hardware store. It ain't regulation, but we won't tell. Start playing your new tailgate game like we do in Texas!
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    I like your design, mainly the fact that it's thinner than most making it great for being easy to carry and transport. We make a few games for tailgating including washers, perhaps we'll incorporate a few of the ideas in later productions.
    Nicely done! Thanks for sharing
    thanks @adamwatters! this was my first go at posting. figured i should pay it forward since i've been using this site for years. don't be shy about voting. ;)
