Step 2Plexi table top
You'll want to drill 3/16 -ish holes to accept the threaded screw of your binding posts. These will also serve as the "legs" for the table. So I used 8 holes, 4 on side centers and the others set in two inches from the ends of the 18.5 length side. It is a good idea to trace the top and mark where the holes are located, you will use this later. Take the trace and mark the hole locations on the frame side pieces of the white vinyl you just cut.
Add Comment
