Step 9FInal assembly
iImage Information
Crawl under your white top surface and carefully secure the previously punched holes, concealed beneath the top stitching to your plexi. You'll want to use your handly Instructables multi-tool to tightening the binding posts. Now you have to stack the gray vinyl right side out and center the plexi LED sandwich into the green foam frame. Find your switch and attach collar/canopy. Carefully line up the edges on fold 1/2" inside and pin, all the way around, and use a thimble because this is four layers of vinyl! Insert your handle ends into the seam on one of the center sides. Move this system to your machine and top stitch that outer edge all the way around.
