Portable Wireless ( Bench/pocket ) Power Supply Booster, 4.5V to 29V, and 5V Phone Charger Also.
942
19
6
Posted
Introduction: Portable Wireless ( Bench/pocket ) Power Supply Booster, 4.5V to 29V, and 5V Phone Charger Also.
This amazing thing,with a capacity of 6400mAh, i use almost EVERY DAY, yes EVERY day. With a lot of extra attachment connectors.
And a little catch!!! i hope somebody notices it.
It will be my Next Instructable.
With the use of an very cool pcb board called the ( XL6009E1 ) 4Ampere pcb
This is a huge helper for every DIYèr.
Its complete with an ON and OF switch, and as extra i added an extra ON and OF switch for the LOAD, for safely changing the Voltage and Current.
This is 1 of the first builds i ever did, as many of you al did. But with my piece of flavor in it to make it a bit different as all the others there are out here.
This IBLE is under construction. And will be ready ASAP.
Step 1: Parts You Need for the Power Supply Build.
1-
The XL6009E1 (the E1 stands only for that its made with lead accid free solder ) so if you buy the XL6009. Its good also to use.
2-
A project box, big enough to put it all in.
3-
2 pcs of li ion phone battery`s 3.7V 3200 mAh each ( i hooked it up in series for double mAh so the voltage stays the same. explanation will be later in the ible.
4-
Wires 24 gage is oke. But thicker is recommended.
5-
2 pcs of ON/OFF switches.
6-
1 JST female connector.
7-
LED voltage display ( 1v/40v )
8- additional
A USB charger output, from a 18650 battery charger kit with capacity of charging 2 battery`s. ( its a booster to 5Volts ) like the normal portable power bank phone chargers sold by the dozens. I just jacked the pcb.
Step 2: TOOLS You Need DEFINITELY
1-
Wire cutter
2-
Soldering iron
3-
Flux
4-
Solder tin
5-
Wire stripper
6-
Glue gun
7-
Phone or camera ( to make the awesome pictures and videos of your BUILD for INSTRUCTABLE )
8-
Double sided tape.
9-
1 seccond glue.
10-
A small flat screw driver
11-
Multi tool or a exacto knife
12-
a file for smoothing the edges.
13-
Patiance.
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Microcontroller Contest
    4 Comments
    test it if you can, by sending a messages again..
    send a test message, BECAUSE 1 year later and it still is not working
    i just seen this, no did not come tru by notification. But you are already on it.
    thanx Tomato
