loading
Step 7: Test Fire!
Before painting the stove I thought it might be a good idea to bake the old paint off. It didn't work entirely, but did make it considerably easier to remove with a wire wheel. You'll notice it's a bit darker in the 2nd photo as the stove begins to heat up.
Also pay attention to how the door and flue operate when hot compared to cold. I noticed they were a bit tighter and I had to file a bit off of the door latch.
<p>this is awesome. If I made one i think i would have a 10-12 inch hinged door like the bottom for the pizza, with a little peeking slide to check it. A flat top for cooking. maybe even use an actual kitchen flat top with a strip on the side for 2-3 pots to sit on a 1/4inch metal plate. pretty much remake an old fire household stove but very small. Even have a second container on its side with the smoke ducted in a way through it similar to a reall smoker. Ive youtubed how to make a camp smoker by placing rocks underground slightly inclining to your smoke box, basically a wood crate over the hole. in a container should be very easy </p>
well.....f&times;&times;&times;&times;&times;g.....done!!!
My wife suggests the smoke pipe should,ve been on the side of the burner. This will save the food from getting sooty. You have already unwanted fumes (thoeritically) from the galvanized tank. Smart instructable. I shall make it soon. <br>Best regards.
Clever suggestion, I hadn't thought of that! Did she mean in the side of the fire pot, or the side of upper cooking chamber? Although the food in the photos looks rather *smoked*, they were the very first cooking trials. After a bit of use I got the knack for it, and the food doesn't end up with any soot at all. Thanks a lot for your thoughts, I'd love to see a picture of yours, I'm thinking of making a MK II also!
Try a powerfull jigsaw with metal cutting blade, on slow speed and take it easy, it'll cut like cheese, I've made one a little different, though not as good as yours, oh, and wear ear defenders! <br>David <br>Scotland
Well the man did say &quot; I was surprised at how easy it was to form considering how thich the metal is. If this doesn't work for you, just use a bigger hammer&quot; <br>
Another one to add to my faves. Too bad it doesn't also do time travel.
Wahahahaha, Andrew, after reading your &quot;diagnosis&quot; ... I'm afraid it's very contagious, 'cause I have very similar symptoms. Anyways, awesome instructable!
Awesome stove. How thick is the metal on that propane bottle? <br>I was thinking of going a little bigger with your idea and using an old air compressor tank. We get alot of the 60 gallon size at our scrap yard. <br>They are about 3/16 of an inch or more and about 20 inches in diameter and about 5 feet 5 inches tall. I might even try to incorperate the oven inside and line with stove cement. What do you think? <br>Thank you for a very creative idea and recycling.
Thanks for the comments, the propane bottle I used was about 3/16&quot; thick as well. The air tank idea sounds great, as does the fire cement trick. Check out this 'ible:<br>https://www.instructables.com/id/Gas-Tank-Pot-Belly-Wood-Stove-budget-approx-35/<br>It looks like he had pretty good success with the cement, although I imagine it would turn it into something more permanent and less portable. Best of luck, and be sure to post some pics!
I'll have the pepperoni and tomatoes !&hellip;<br><br>And, please, please ! &hellip;&nbsp;REMEMBER to give your real address so I can invite myself next time I come to America. You will be the first person I will visit in my journey : I alway thought that good food a the beginning of a trip is good omen. <br>Yours cannot be better !!!&hellip;<br><br>OK! Joke apart : you did a wonderful job.
Ha ha, thanks for the comments! I'm sure they do great pizza in America too, but next time you're in New Zealand just follow your nose, I'll keep the wood fires burning!
NEW ZEALND ????<br>So again I made a fool of myself !!!<br>I may as well change my plans and visit NZ great sailing place where I always wanted to visit and sail around !!!&hellip;<br><br>Right now I' testing the direction of the wind to find if it blows in the right direction !!!<br><br>Take care.
&quot;put it in the parking lot, and ran it over with my bus a few times to flatten it out,&quot;<br><br>Epic move!!!<br><br>
I like the way you have gone further than the usual gas bottle idea and created a cooker too. I currently have two redundant butane bottles (standard portable cabinet heater size) and I'm thinking of welding them side by side. One half would be a standard gas bottle burner with the other having some shelves in it to use as an oven. <br> <br>I think I'll start small and do a stove first though :) <br> <br>I am so glad I found this site, I think it is awesome. <br> <br>Take care all. <br> <br>Kevan
Nice job! I'm currently knee deep in converting a 250 gallon propane tank into a giant smoker. One tip, on the hinge. . if you get a good amount of rain, that hinge type will often seize up on you, if it stays outside. You're much better off, using barrel hinges, like these. . . <br>http://www.kingmetals.com/default.aspx?page=item%20detail&amp;itemcode=44-2020<br><br>well done. . .
Your oven is at least a ton lighter than mine. That would be awsome at the beach!
There are a few good ibles on converting gas bottles to stoves...but this one is right at the top of the heap....very good thanx.
Be very careful cooking on that if it is indeed galvanized! Same with welding it.. that stuff puts out EVIL mojo fumes when heated!
wauu<br>very nice.<br>a men work ;P
You are very creative! :)
I really like what you have done here. I have thought about doing something similar on a smaller scale to recycle the tanks that you can get with the helium balloon party kits. I have a couple and you have given me real food for thought.
Bro - that's a really nice build! Great example of Kiwi ingenuity - keep em coming.
I lift a pint in your general direction sir! Nice work.
I love the lid and flat griddle... I haven't seen that before on recycled wood burners
5 of 5 !!!
About This Instructable
72,304views
303favorites
License:
Bio: I work in IT, but enjoy a variety of things. I'll usually do something until I'm almost good at it and then move ... More »
More by andrew.spencer.2:Heated Hoodie Bubbly Glass Bead Bracelet Power Tool USB Charger
Add instructable to:
