Introduction: Portable and Recycled Guitar Amplifier
Picture of Portable and Recycled Guitar Amplifier
Presented Here is the Guitar Amplifier. The best part of this project is that it is recycled and portable. It is made up of old chocolate box. It is portable and easy to carry. It has various types of facilities. It has volume control to increase or decrease the volume.
Besides Guitar Amplifier, it can be used as versatile speaker. Just give input at the jack with the help of AUX Cable. You can also use it as a speaker. It has a very loud voice. So, it is advisable to keep its volume low.
The circuit for this Guitar Amplifier is extremely simple and beginners can also try this out. The circuit is built around LM 386 IC which is very well known in the field of audio circuits.
I am sure you will find this instructable interesting and worthy!!!!
DON'T FORGET TO FAVORITE AND VOTE THIS INSTRUCTABLE!!!!
Step 1: Materials Required
Picture of Materials Required
1. LM 386
2. 220uF Capacitor
3. 0.47uF Capacitor
4. 10 ohm Resistor
5. 10k Potentiometer
6. 2 pin Coonnector x 2
7. 3 pin connector
8. 9v Battery
9. Battery Snapper
10. Case
11. Loudspeaker
12. Some Tools
13. Female Audio Jack
Step 2: Circuit Diagram
Picture of Circuit Diagram
The circuit is built around LM 386 IC. LM386 IC is the low voltage audio power amplifier. It is suitable for battery-powered devices such as radios, guitar amplifiers, and hobby electronics projects. The IC consists of an 8 pin dual in-line package (DIP-8) and can output 0.25 to 1 watts of power depending on the model using a 9-volt power supply.
Following the circuit diagram you can make your circuit for the Guitar Amplifier.
Here 10k Potentiometer is for volume control.
Female Audio Jack should be used at audio input.
Step 3: Circuit on Breadboard
Picture of Circuit on Breadboard
Now, following the Circuit diagram we will try to make the circuit on breadboard. Let's Get started.
First of all, mount LM386 IC on Breadboard
Connect its pin no. 2 and 4 with the help of a wire.
Step 4: Still Making....
Picture of Still Making....
Now, attach a 0.47uF Capacitor such that its positive terminal connects to pin no. 5 of the IC.
Then connect 10 ohm Resistor across pin no. 4 of the IC and negative terminal of 0.47uF Capacitor.
Step 5: Work in Progress
Picture of Work in Progress
Now, connect 220uF Capacitor such that its positive terminal connects to pin 5 of the IC.
Attach a 2 pin connector for output at speaker with at one terminal negative terminal of 220uF Capacitor and other connected to pin no. 4 of the IC.
Step 6: Somewhat Completed
Picture of Somewhat Completed
Now, attach a 3 pin connector for potentiometer. Second terminal of connector is to be connected to pin no. 3 of the IC.
The last terminal (from any side) should be connected to pin 4 of the IC.
Step 7: Power Supply
Picture of Power Supply
Now, power supply is to be given at pin 6(Positive) and pin no. 4 (Negative) of the IC. 9 Volt Battery is to be connected.
Audio input is available at 10k potentiometer and pin no. 4 of the IC.
Step 8: Make It on Circuit Board
Picture of Make It on Circuit Board
Now, assemble the components on the circuit Board according to the circuit Diagram. Here connectors are given for speaker, potentiometer and audio input.
Wait for the next step till you connect the battery snapper.
Step 9: Switch
Picture of Switch
Connect the negative terminal of the Battery Snapper to the pin no.4 of the IC. But you have to connect a switch between the positive terminal of battery snapper and pin no. 6 of the IC.
Now, connect a switch in between such that when you turn on the switch you can get the power.
Step 10: Case
Picture of Case
I am using a Chocolate Box as a case. You can use other items but make sure that the material is non conductor of electricity.
Step 11: Holes
Picture of Holes
Make holes on the cap of the box for switch, potentiometer and female audio jack.
Step 12: For Speaker
Picture of For Speaker
Put the speaker on the cap of the box where you want to fix it and make the outline of the speaker. Now, make the dots inside the circle you have made. These will be the holes for the speaker's voice to come out.
Step 13: Make Holes
Picture of Make Holes
Now, make holes the place where you have dotted and it is better to keep the holes' size smaller.
Step 14: Connectors
Picture of Connectors
Make sure you have long connector wires to make connections far from the circuit board.
Step 15: Solder
Picture of Solder
Solder the connector wires to the components. Be aware while soldering potentiometer and audio jack. Solder the wires as per the polarity of audio jack.
Step 16: Connect Speaker
Picture of Connect Speaker
Connect the speaker at the connector that is highlighted in the image of circuit board.
Step 17: Other Connections
Picture of Other Connections
Now, connect other items such as potentiometer and audio jack to the circuit board as per their connectors.
Step 18: Fix the Speaker
Picture of Fix the Speaker
Now, fix the speaker with the help of super glue at the outline made before.
Step 19: Fix All
Picture of Fix All
Now, fix all the other components in their holes such as switch, potenetiometer and female audio jack.
Now, connect 9v Battery and close the box and get started.
You can use AUX Cable for Audio Input.
Step 20: Finally Nailed It!
Picture of Finally Nailed It!
Finally, You have made your own Guitar Amplifier.
Thanks for Stopping By!!!!
Rock On!!!!!!!!!!!
GarrickS (author)2017-07-01
Good job/ is it possible to Make some hvy duty amps like Marshall ?
Patel Darshil (author)GarrickS2017-07-01
Thanks. You can make it but not with this circuit. The IC is a low power audio amplifier.
nancyjohns (author)2017-06-22
Awesome. I'll have to make one of these sometime.
Patel Darshil (author)nancyjohns2017-06-22
Thanks. I am happy you enjoyed it.
Ace Gambit (author)2017-06-19
Very cool! how does it sound?
Patel Darshil (author)Ace Gambit2017-06-19
Thanks and it sounds loud like every loudspeaker sounds.......
pooter1433 (author)2017-06-15
Good job buddy! I suggest more or larger speaker holes but cool job. Rock on!
Patel Darshil (author)pooter14332017-06-15
Thanks!!!!
About This Instructable
3,704views
66favorites
License:
Bio: Hello, I am 17 year old innovator living in India. My interest lies in Electronics. Surf through my creations and enjoy!!!!1
More by Patel Darshil:Tame the Beast! Make a Solar Powered Arduino UnitRobotics and Automation Shrinked With BABYDUINOThings You Should Know Before Using ESP8266 Wifi Module
Add instructable to:
